Help! Why? Blown 120A alternator fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bmcmahan, Jul 14, 2018.
  1. Jul 15, 2018 at 1:03 PM
    Muddinfun
    Muddinfun Well-Known Member
    Use a test light or multimeter and check each side of all of the fuses with the key off. Any that have power on 1 side and not on the other are blown. After that, turn the key on and do the same thing. Be sure to check the fuse box behind the cubby in the dash. If you're really really really really really really lucky, no electronics are blown.
  2. Jul 15, 2018 at 1:04 PM
    Bmcmahan
    Bmcmahan [OP] Member
    2011 Tacoma 2wd 4door pre-runner V6
    Thank you we were actually trying to find that fuse box!
    Muddinfun likes this.
  3. Jul 15, 2018 at 1:09 PM
    Muddinfun
    Ign1 no2 is a fuse that you need to be sure to check.
    If everything is normal, the check engine light should light when you turn the key on and then go out when the engine starts.
    Sandman614 and TireFire like this.
  4. Jul 15, 2018 at 1:13 PM
    Bmcmahan
    Ok so check that one and it was good, but found and replaced the ETCS... about to take a test drive now that we have throttle, but the check engine light is still on...
  5. Jul 15, 2018 at 1:17 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    If the check engine light is on while the motor is running you should pull the code. Autozone or such places will do it for you if you don't have a reader. Then post your code here.
  6. Jul 15, 2018 at 1:17 PM
    Muddinfun
    Sounds good. You're making progress. Another test you need to do is put a voltmeter on the battery with the engine running. It should be between 13.8 and 14.4 volts. If not, then the alternator is fried.
  7. Jul 15, 2018 at 1:18 PM
    TireFire
    Olympic Peninsula
    Actually anything over 13V is alright. May sound low but this is normal for Tacos.
    Also if the alternator isn't charging and the truck is running only on battery juice then the red battery light in the left side of the gauge cluster should light up
    MolonLabeTaco and OriginalMan like this.
  8. Jul 15, 2018 at 5:59 PM
    sr52008tacoma
    sr52008tacoma Active Member
    its called an etc or etcb fuse or something like that meaning the electric throttle control. I believe its under the hood.
  9. Jul 15, 2018 at 9:09 PM
    Muddinfun
    @Bmcmahan well??? How did the road test go? Should we send out a search party?
    PzTank likes this.
  10. Jul 17, 2018 at 1:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    PzTank likes this.
  11. Jul 18, 2018 at 8:37 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    +1.
  12. Jul 18, 2018 at 8:41 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Jimmmmmmmmmmmmmayyyyyyyyyyy
  13. Jul 18, 2018 at 9:26 AM
    PzTank
    Above the Notches
    Didn’t want to go the Deniro route :D
  14. Jul 18, 2018 at 9:30 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    No @Jimmy 123
    PzTank[QUOTED] likes this.
  15. Jul 18, 2018 at 10:45 AM
    #35
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  16. Jun 2, 2025 at 7:15 PM
    #36
    l Ringo l
    l Ringo l New Member
    Bringing this thread back to life…
    Like a dummy I hooked up my battery backwards in my 07 taco. Truck wouldn’t start. Replaced 140amp alternator fuse, radio, ABS, and some sort of throttle control fuse (I think) as they were all blown. Anyway, truck ran fine a few trips around town but then blew the 140 amp alternator fuse again.
    Going to check voltage to the battery tomorrow. Any other ideas?
  17. Jun 2, 2025 at 7:17 PM
    #37
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Never had a problem no matter which way I hooked it up.
  18. Jun 3, 2025 at 7:24 AM
    #38
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    PERHAPS the alternator (regulator/rectifier) was damaged but marginally working for awhile then finally gave out and started pumping out AC, which would appear as a periodic "reversed battery."
  19. Jun 4, 2025 at 6:58 AM
    #39
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    A fast check of the internal rectifier is to start the truck and measure for AC voltage at the battery leads (after the alt fuse is replaced). Rectifier Diodes (when they go bad) ether open up or short, opening up causes the alt charging output to reduce or go away completely (confirmed by measuring only battery voltage all the time when running, no influence from the alt). Or else a diode can short allowing A/C voltage onto the truck's harness. There's multiple diodes so results can/will be affected by how many were damaged. A simple voltage check at the battery terminals with the meter set to AC voltage will verify or eliminate a shorted diode, (normally an a/c voltage check should show less a volt of AC at the battery).
