Help! Why is my engine doing this?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Narlew, Feb 13, 2025.
  1. Feb 13, 2025 at 9:03 AM
    Narlew
    Narlew [OP] Well-Known Member
    davidstacoma likes this.
  2. Feb 13, 2025 at 9:07 AM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Upload video on the youtube and drop link here.
    What you mean surging? any weird sounds ? vibration or? dont drive it if you think something is wrong, just take short video
  3. Feb 13, 2025 at 9:09 AM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Bad gas or fuel pump?
  4. Feb 13, 2025 at 9:24 AM
    Narlew
    Edited....uploaded to YouTube. When I put it in drive it's doing the same thing....surging like I'm pressing the gas pedal over and over.
  5. Feb 13, 2025 at 9:28 AM
    scocar
    scocar Patron of the Farts
    Holy crap. WTF.
  6. Feb 13, 2025 at 9:41 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Idk, subbed to find out
  7. Feb 13, 2025 at 9:44 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Does it stumble or clear up as you get on the gas in neutral?
    If you had doe plugs or anything under the hood recently a culprit could be a vacuum hose thats been left off or knocked off by accident.
  8. Feb 13, 2025 at 9:48 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    What happens when the engine is warm?
    Phlogiston likes this.
  9. Feb 13, 2025 at 9:49 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That's weird, but it doesn't seem like it is going to blow itself up. If you give it some more gas and hold it steady above 1500 RPM, does it still surge up and down? Hopefully it will set a code if you let it run long enough.
    Seems like maybe bad gas, or maybe a vacuum line somewhere popped loose or cracked?
    musicisevil and t0p_d0g like this.
  10. Feb 13, 2025 at 9:53 AM
    timw1
    timw1 Well-Known Member
    Tim
    Arapahoe, NC
    2023 Tacoma TRD OR DCSB
    Throttle position sensor?
  11. Feb 13, 2025 at 9:54 AM
    Tacosauro
    roof rack
    It sounds like its trying to get fuel but its not pumping? or something like that. I feel like ignition is not happening in the engine, now hood is closed so we can't hear that well but it sounds like that to me. Some others are more experienced here so lets wait and see what most will say
  12. Feb 13, 2025 at 9:57 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  13. Feb 13, 2025 at 9:58 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    It could be the IAC sensor, just a guess hopefully it will throw a code.
    Area51Runner likes this.
  14. Feb 13, 2025 at 9:58 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Are you smelling gas in the engine bay?
    There is a fuel pump recall. Your 2019 is covered for 10 years regardless of mileage.
    https://static.nhtsa.gov/odi/tsbs/2023/MC-10236191-9999.pdf
    SWPA Tacoma, Steves104x4 and t0p_d0g like this.
  15. Feb 13, 2025 at 10:01 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Try to rev it up while in neutral while it’s surging and see if it will rev up or not.
  16. Feb 13, 2025 at 10:03 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It's almost behaving like an carbureted engine with a sticky float valve. Very strange.
  17. Feb 13, 2025 at 10:04 AM
    Narlew
    Was out letting it run and now the idle is better but trac off and check engine light is on. Gas pedal was slow to respond but revved it up to 2k ram and held it a bit and now it smoothed out at idle.
  18. Feb 13, 2025 at 10:05 AM
    twtaco$
    twtaco$ Well-Known Member
    Air filter clean? Pull it out and see if that stops if not move on to next suggestion
  19. Feb 13, 2025 at 10:08 AM
    TA2016
    Oregon
    If you can get the trouble codes read, let us know the codes.
  20. Feb 13, 2025 at 10:08 AM
    Tacosauro
    roof rack
    Try OBD, see if its reading any codes, dont drive the car
