Help! Wierd squealing noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by ERIC, Nov 15, 2010.
  1. Nov 15, 2010 at 4:04 PM
    ERIC
    ERIC [OP] Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    I Have a six lug prerunner and i am getting this wierd high pitched squealing sound from the front end of the truck, I think towards the right side. It only happens sometimes though and only when I am cruising. At first I thought it might be the belts cause i have not gotten to changing them yet and I have 92,000 miles on it. But could it be a front wheel bearing going out?
  2. Nov 15, 2010 at 4:07 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Maybe the A/C? Brakes? Gremlins?
  3. Nov 15, 2010 at 4:10 PM
    ERIC
    Eric
    Orange County, CA
    probably gremlins lol. I normally never run the A/C though so I dont think thats it, and it never squeals when i hit the brakes. So idk lol
  4. Nov 15, 2010 at 4:17 PM
    DaCapt
    DaCapt Mad Fisherman
    Phil
    Reno, Nevada
    2013 Tacoma 4X4 SR5 DC
    Check for rocks stuck between the brake rotor and rotor dust shield. This happened to me and it makes a terrible noise.
  5. Nov 15, 2010 at 5:55 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    is it engine speed related, ground speed related, etc?
  6. Nov 15, 2010 at 9:43 PM
    ERIC
    Eric
    Orange County, CA
    id say more engine speed. usually happens wen cruising around 1500-2300 rpms mostly on the freeway
  7. Nov 15, 2010 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think he meant, if the rpms change, does the squeal change
  8. Nov 16, 2010 at 7:00 AM
    pittim
    Pennsyltucky
    Boujee Prius
    so if you're at 2200 and not on the freeway it doesnt make the sound?
  9. Nov 16, 2010 at 12:17 PM
    ERIC
    Eric
    Orange County, CA
    it only happens sometimes but mostly on the freeway around 2000. im leaning towards wheel bearing going out.
