HELP will crank but not start
Discussion in '1st Gen. Tacomas (1995-2004)' started by riven29, Dec 15, 2022.
  1. Dec 15, 2022 at 7:52 AM
    riven29
    riven29 [OP] Well-Known Member
    1995 Maroon Tacoma
    Hey guys I’m stumped here and hoping for some help. I noticed yesterday that my 95 3.4L yesterday had a coolant leak. Pressure tested and found it was the thermostat housing that was leaking. Drained the coolant, pulled the housing sure enough gasket was put on wrong by previous owner. Replaced everything, filled coolant back up. Now when I try and start the truck it cranks but won’t start. I have confirmed that I have spark, it’s not my fuel pump, starting fluid in the intake has no effect. Hopefully one of you Toyota gurus has a suggestion! Thanks guys!
    wilcam47 likes this.
  2. Dec 15, 2022 at 8:05 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    it was fine until thermostat replacement?...where there any ground wires you took off
  3. Dec 15, 2022 at 8:13 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Check I think its the cam sensor that's in that area. Crank sensor is below as well (for 3rz at least). It's most likely a sensor that might have been accidently unplugged.
    FrankTheTank858 likes this.
  4. Dec 15, 2022 at 8:24 AM
    riven29
    1995 Maroon Tacoma
    It was running fine besides the small weeping of coolant from the thermostat housing prior. Didn’t remove and ground wires that I know of
  5. Dec 15, 2022 at 8:25 AM
    riven29
    1995 Maroon Tacoma
    I’ll have to take a look for that!
  6. Dec 15, 2022 at 8:28 AM
    FrankTheTank858
    FrankTheTank858 Well-Known Member
    Frank
    Murrieta, CA
    2006 Tacoma DCSB 4WD
    Maybe a vacuum hose left loose as well?
    check the sensors previously stated and any hoses that you may have removed.
  7. Dec 16, 2022 at 12:34 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Yep, check that sensor right by the thermostat housing.
  8. Dec 28, 2022 at 8:09 PM
    riven29
    1995 Maroon Tacoma
    Ended up being the crank position sensor. A little coolant snuck in and got on the contacts as I pulled the thermostat housing out i guess. Dried it all and put a new “gasket” on the plug and works perfect now. Thanks for the help guys!
  9. Dec 30, 2022 at 7:28 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Thanks for following up with solution!
