Help! Wire Popped Out <PICS>
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teslabolt77, Sep 14, 2018.
  1. Sep 14, 2018 at 12:08 PM
    teslabolt77
    teslabolt77 [OP] Active Member
    The green wire to my brake controller plug under the dash has released itself from the pin. Anyone know what type of pins they are? I bought a couple of kits on Amazon but I have no clue which one to use for this specific molex connector.
    Thanks!
  2. Sep 14, 2018 at 12:15 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    NRH, TX
    2015 DCSB PR
    Clazzios, 3G OR suspension, Debadged, TRD Skid, Kenwood HU.
    You should be able to use an ice pick or something of the sort and push the metal thing out from the front side. The metal part should have a little part holding it in place that you can depress and push it out the back. Then strip your wire and crimp it back on then push it back in its place.
    PzTank, BassAckwards and DirtJumper14 like this.
  3. Sep 14, 2018 at 12:17 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, Homertaco big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    ^ What he said. Although, an ice pick may be too big. Try a jewelers screwdriver or a straight pick.
    There is a barb that sticks up and wedges into the plastic. Just have to bend that down to release it.
  4. Sep 14, 2018 at 12:21 PM
    Mitch76
    Mitch
    NRH, TX
    2015 DCSB PR
    YES, Barb! Thats the damn word i was looking for.
  5. Sep 14, 2018 at 12:28 PM
    teslabolt77
    Thanks gents,
    is there just one barb, and if so which side are they typically on?
    Assuming I would push toward the wired end?
  6. Sep 14, 2018 at 12:29 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Greg
    Las Vegas
    2017 Pro/2015 Tacoma
    Lifted
    Small slim nose pliers or tweezers and pull it out.
  7. Sep 14, 2018 at 12:35 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    Usually there is only 1 barb. You should be able to see it sticking up and into the plastic. It varies by plug on location. And yes it should slide out the wire side.
  8. Sep 14, 2018 at 12:39 PM
    Mitch76
    Mitch
    NRH, TX
    2015 DCSB PR
    I wouldnt pull it out without depressing the barb first. It can break the super thin metal barb and then wont stick once you put it back in. Trust me, ive done it.
    PzTank and DirtJumper14 like this.
  9. Sep 14, 2018 at 12:39 PM
    Muddinfun
    Muddinfun Well-Known Member
    In the 2nd pic, it looks like it has the plastic flap on the side that you have to lift up first.
    Somebody has done some monkey moo work on those wires. Those aren't the factory crimps.
    Jimmyh and DirtJumper14 like this.
  10. Sep 14, 2018 at 12:42 PM
    teslabolt77
    Yeah, nothing is working. I have used all sorts of small picks and tubular tool designed just for this and none of them work. It's a little hard because I have no wire to pull on once i have it released. Might be buying a new pigtail. Ugh.
  11. Sep 14, 2018 at 12:44 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    It also looks like that the metal pin has some damage on the connection side. May want to check the male plug to make sure that pin is straight as well.
    Try a paperclip or even a needle from the wifes sewing kit. It should slide out with little effort once released.
  12. Sep 14, 2018 at 12:49 PM
    Mitch76
    Mitch
    NRH, TX
    2015 DCSB PR
    I noticed that too. Might not be worth the effort if the metal piece is damaged. Might not make a good connection once you get the wire back in.
    DirtJumper14 likes this.
  13. Sep 14, 2018 at 12:50 PM
    teslabolt77
    Yeah, that was me from me trying to push it out. If I do get it out, I can easily replace it with one from Radio Shack.
  14. Sep 14, 2018 at 12:58 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    Deforming the pin may make it harder to get out btw. If it's shot just bend it close to it's original shape and it should come out (after barb is bent). Just make sure the replacement is identical. Otherwise it probably won't stay in place.
    teslabolt77 [OP] likes this.
  15. Sep 14, 2018 at 1:35 PM
    teslabolt77
    Turns out that the brake control plug adapter harness is not using that wire anyway. Sheesh.
    I did learn that this little door on top opens up to unlock the wires. Win win.
    Mitch76, PzTank and DirtJumper14 like this.
  16. Sep 15, 2018 at 8:55 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    If you still need the correct crimp pin look for the part number molded onto the Molex connector then look up the data sheet on the Molex website. I recall they usually list the crimp pin as well as the mating connector on their data sheets.
    PzTank likes this.
  17. Sep 20, 2018 at 11:31 PM
    caribe makaira
    Caribbean, Puerto Rico
  18. Sep 21, 2018 at 5:45 AM
    96carboard
    96carboard Well-Known Member
    Rather than fighting to get the pin out of the plug, just get out your soldering iron and solder the wire onto the pin. Solder will hold it better than anything (about 100x better than it was ever held in there before), and there is plenty of room in there to solder it.
    Prepare the two sides by "tinning" them in advance (means melt some solder onto the wire, and melt some solder onto the pin), then add a blob of solder to your iron tip, hold the wire in place, and all you need to do is touch them with the soldering iron for half a second and it will be permanent.
