Help wiring ARB CKMA 12 compressor to CH4x4 switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrlin718, Mar 7, 2017.
  1. Sep 11, 2018 at 5:58 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    God bless the invention of black keyboards.
    DJSPEC likes this.
  2. Sep 11, 2018 at 6:17 PM
    alanphoto
    alanphoto Active Member
    Alan
    2017 Off Road
    Thanx so much for the quick reply!!
    Cheers,
    AL
  3. Sep 12, 2018 at 5:51 AM
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    I also have the ARB Twin and used a CH4x4 switch and have had no problems without a relay.
    OverlAnderson likes this.
  4. Sep 12, 2018 at 6:11 AM
    alanphoto
    Alan
    2017 Off Road
    @COSD Thanx so much for your reply!! I really appreciate it!
    AL
  5. Sep 12, 2018 at 7:04 PM
    Taco Juice
    Taco Juice Active Member
    2017 OR QS
    ICON STAGE 4, ICON ALLOYS 285/70R17, BHLM Halos, multicam black vinyl, Pro grill
    The ARB does have an internal relay, I used a separate relay when adding the CH4x4, call me paranoid, but I don’t want to risk a dash fire
  6. Dec 17, 2018 at 6:10 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    so im in the same situation as you were. ive been told the twin has a build in relay so no relay is needed. im assuming you've already got this installed how was the install process?
  7. Jan 23, 2019 at 5:06 AM
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    wired up my ARB dual yesterday. i wired it to my Spod with the 4 wires that go to the switch. I sent the 6guage wires (redx2 and black/white with ground) to the battery. the black and purple were the neg and pos I put to the spod switch. it works great I am just curious on what are the yellow and green wire for? ive capped and stowed them for now
  8. Jan 23, 2019 at 5:53 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    There's a wiring diagram in the install manual.
  9. May 27, 2019 at 5:40 PM
    mrjoshyman
    mrjoshyman Well-Known Member
    Josh
    so just to confirm, you wired this using the isolation switch harness? rather than switch 1/2? the ARB instruction are garbage
  10. May 27, 2019 at 5:55 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Hard to argue, pictures are hard.
  11. May 27, 2019 at 6:01 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I didn’t have any issues with the diagram or instructions. I have some electrical background so reading the wiring as a schematic made sense to me.
    Sandman614 likes this.
  12. Sep 17, 2019 at 6:49 AM
    Grey_TRD Tacoma
    Grey_TRD Tacoma Well-Known Member
    Jamie
    Tampa Florida
    2016 TRD Sport 4x4
    32x10.50 falken wildpeaks OME 887 coils Bilstein 5100s Dirt King UCAs OME Lean plate ICON AAL RCI front skid RCI rock sliders
    I’m glad I found this thread, I’m hoping to install my ARB single this weekend. But I need the OEM switch and switch panel for the cubby hole.
    Is everyone’s CH4x4 switch, wired directly in with no relay still going strong?
  13. Feb 4, 2020 at 10:01 PM
    PilotMM
    PilotMM Well-Known Member
    Las Vegas
    '17 TRDOR DCSB
    RLD Canopy, Icon Stage 4 plus RXT leaf
    Thanks!
  14. Jun 30, 2020 at 9:47 PM
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    So I bought a CH4X4 switch for my compressor. A question I have is that the isolation switch is my on/off switch for the compressor correct? Switch 1 will be the switch for the rear locker correct?
  15. Jul 1, 2020 at 5:11 AM
    #35
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Correct.
    lamjam[QUOTED] likes this.
  16. Apr 23, 2021 at 11:05 PM
    #36
    NFaridi
    NFaridi New Member
    For the illumination wire, has anybody taken the BLUE/WHITE illumination wire on the ARB harness and spliced into an illumination wire off one of the factory switches?
    If doing so this way, can we skip having to use a FUSE TAP into the fusebox for illumination?
  17. Apr 24, 2021 at 8:02 AM
    #37
    PilotMM
    Las Vegas
    '17 TRDOR DCSB
    I tried that and didn’t get the dim function to work right. When I had it tapped to the green it would dim in reverse. When I had it tapped to the ground it wouldn’t dim at all. I am using a CH4x4 switch and the add a fuse just seems to work.
    -M
  18. Apr 24, 2021 at 8:52 AM
    #38
    NFaridi
    NFaridi New Member
    Fair enough, thanks for sharing!
    PilotMM[QUOTED] likes this.
  19. Oct 6, 2021 at 9:01 PM
    #39
    lylefk
    lylefk Well-Known Member
    Maui, HI
    '21 4wd Cement Sport DCSB
    Nothing major
    Hi there,
    Sorry to dredge up an old thread, but I'm assuming this diagram is still correct?
    I'm installing the single, it sounds like the twin doesn't need a relay added. Do I need to run one with the single, and if so how does it change the wiring?
    Thanks for the help, looks like I've got to get a couple fuse taps.
    Lyle
  20. May 1, 2022 at 11:06 AM
    #40
    TheIncredibleTaco
    TheIncredibleTaco Well-Known Member
    Denver, CO
    2021 TRD OR DCSB
    Exhaust reroute RCI steel full skid plates (front, transfer case, transmission) Front camera (anytime backup camera) RCI rock sliders AC Drip mod OEM locking tailgate Brite box fogster anytime fogs Backwoods adventure mods hi-lite front bumper with Baja designs squadron pros ARB single OBA Fox 2.5 PES DSC 2-3” Wheelers superbumps + ubolt flip kit Deaver stage 1 u402 Cab mount chop+fender trim Rrw RR-7 -12 offset with 315/70r17 5.29 regear ARB front air locker Z precision big cupholder
    No there’s a relay with the single. The box plugs into your harness in the engine bay. Has a number 180905 and states 12V 40A on it
