Help Wiring Auxiliary Reverse Lights
Discussion in 'Lighting' started by rolltide3705, Jun 23, 2011.
  1. Jun 23, 2011 at 7:48 PM
    rolltide3705
    rolltide3705 [OP] Well-Known Member
    A.J.
    Birmingham, Alabama
    06 Prerunner Sport Double Cab
    I was hoping some of yall that have more experience in wiring and such could help me with some of my questions I have about wiring up some auxiliary reverse lights. I know I am just a teenager that doesn't know much about anything when it comes to stuff like this, that's why I joined this site and why I'm asking for yalls help.
    Here are the lights I plan on ordering: http://www.northerntool.com/shop/tools/product_352681_352681
    They're very cheap so if they get smashed they will be easy to replace.
    What I want to do is use an on/off/on switch so that i can run these lights in reverse and also be able to turn them on whenever I need to, along with having an off position.
    I want to order a switch from this site: http://www.otrattw.com/index.php
    So which switch would suit my needs? and how do I wire it up?
    Now for the area that the real help is needed. I think I've read through every thread about wiring auxiliary reverse lights on every Toyota forum out there. Having said that, they might as well be in a foreign language to me.
    I know I will need to use a relay and possibly a diode?
    What size wire do I need to use?
    How do I ground them properly without blowing a fuse?
    I also don't know how to read any diagrams
    What does the 87, 86, 85, and 30 mean?
    What if I don't have an auxiliary fuse panel?
    If someone could help me out and break down this diagram for me and just give me a step by step of how to wire these lights it will be greatly appreciated!
    As I said I am completely clueless and would really appreciate somebody helping me out and teaching me about wiring/ working on my truck!
    Thanks for all the help in advance
  2. Jun 23, 2011 at 9:07 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    One answer.. You don't have an extra fuse block unless you order it and add it yourself.
    2nd answer... I know i might have done it the wrong way but i bought some cheap $10 lights from walmart and spliced them in directly to the reverse light power wire. Then i grounded them separately and splice them in separately.. They work great but it would be smarter to use a relay!
  3. Jun 23, 2011 at 9:28 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Thanks for the response Kyle,
    I was thinkin about just splicing into the reverse lights but i kind of want the convenience of being able to use them whenever i need them, not just in reverse. if i cant figure it out I may just go with that route though
  4. Jun 24, 2011 at 7:17 AM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Morning bump*
  5. Jun 24, 2011 at 7:45 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    i'm the one who drew that diagram. the auxiliary lights are wired to the stock reverse lights. i wanted the lights to turn on when the truck was put in reverse, but i also wanted to use the lights independently... that's the purpose of the diode. current can only flow in one direction threw a diode. that also explains why i have two power sources. when the oem switch that i used is pressed, the stock reverse lights won't come on when the auxiliary lights are used. i'll try to explain better if you need me to.
  6. Jun 24, 2011 at 8:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    http://www.mp3car.com/the-faq-emporium/117895-faq-relays-how-they-work-and-how-to-wire-it-up.html
  7. Jun 24, 2011 at 8:09 AM
    griffin407c
    Upstate NY
    ^ exactly what he said
  8. Jun 24, 2011 at 11:33 AM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Thanks for all the responses guys. I think Im almost there.
    So since I don't have an auxiliary fuse box i would put an in-line fuse on the wires that come from the 30 and 85 on the relay that connect to the positive and negative on the battery?
    Also I was planning on using an on/off/on switch. Will this work the same way you have drawn it up on the diagram or does the way youve drawn it up have the aux reverse lights come on automatically when you put it in reverse, then when you push the switch in the aux. reverse lights come on independently?
    sorry if that sounds really confusing. Also what did you connect the switch to for the ignition power source?
    Thanks for all yalls help I really appreciate it!
  9. Jun 24, 2011 at 11:45 AM
    Pugga
    Massachusetts
    I hope this helps! Can you solder and heat shrink wires? Don't just wrap wire splices in electrical tape!
  10. Jun 24, 2011 at 12:02 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Thanks that definitely helps. I now undrestand the relay, in-line fuse, and the grounding.
    My original plan with the on/off/on switch was one on position allows the lights to turn on when in reverse, the other on would allow me to use the lights whenever and the off would be off at all times. The way you've drawn it though is much more simple.
    If it isnt too much of a hassle could you go to the link above and find the type of switch I would need to use?
    I feel fairly confident that between my dad and me, we can solder and heat shrink the wires together.
    If you could find out the location in the fuse panel and possibly get a picture that would be awesome.
    I know im probably asking a lot but I really appreciate all the info you've given me and I already feel a lot more confident with this project!
  11. Jun 24, 2011 at 1:30 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
  12. Jun 25, 2011 at 1:14 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    afternoon bump* almost there
  13. Jun 27, 2011 at 4:20 AM
    griffin407c
    Upstate NY
    any switch is capable of working. figure out which switch you want to use and i can draw you a quick diagram, to help you out through the process.
  14. Jun 27, 2011 at 4:43 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I used the reverse light wire on the trailer harness, center wire if you are so equipped.
  15. Jun 27, 2011 at 8:08 AM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Im going to use this switch: http://www.otrattw.com/proddetail.php?prod=V1D1J66B-ASC77-18B
    I modified your diagram to what I thought would be correct from what yall have told me. Does this look right? That black box is the in-line fuse
  16. Jun 28, 2011 at 6:03 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
  17. Jun 29, 2011 at 10:14 AM
    griffin407c
    Upstate NY
    that diagram is exactly what i was goin to draw you. the switch will work, no doubts. im not exactly sure how to wire it up tho, without looking at it. it's probably pretty straight forward. you're goin to have to splice it into the stock switch wiring to work in unison.
  18. Jun 29, 2011 at 10:28 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
  19. Jun 29, 2011 at 3:51 PM
    Bruce K
    Bruce K Member
    Bruce
    SW Washington state
    04 TRD
    Bilstein 5100's, Wheelers 5 leaf pack, OME 581
    I used the wiring diagram in post number 64. I used a SPDT switch.
  20. Jun 30, 2011 at 6:28 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Sounds like you're well on your way...check out my electrical basics thread for info in the future (link in signature). Good luck.
