Help Wiring Auxiliary Reverse Lights
Discussion in 'Lighting' started by rolltide3705, Jun 23, 2011.
  1. Jul 27, 2011 at 4:10 PM
    rolltide3705
    rolltide3705 [OP] Well-Known Member
    A.J.
    Birmingham, Alabama
    06 Prerunner Sport Double Cab
    Got the lights in the other day, just ordered the switch. I've been out of town for almost 3 weeks but it's finally comin together!
  2. Jul 27, 2011 at 6:56 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    you should come up to the meet this Saturday if you can...
  3. Jul 27, 2011 at 7:02 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Damn man I wish I could but Im goin to the lake with some friends. I swear everytime we have a meet somethin comes up. Ill have to change that one of these days
  4. Aug 7, 2011 at 8:31 AM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Can any of yall tell me which one is positive and negative from the lights? Also there's a picture of my switch.
  5. Aug 8, 2011 at 5:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Doesn't appear as though it matters (some simple wiring applications, it doesn't matter which you use for the positive and the ground). If I had to make a decision, on the third picture, the wire on the bottom is the one I'd use as the ground.
  6. Aug 8, 2011 at 9:38 AM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Ok thanks, that's what I thought. Also do you think you could take a picture of what you connected to for the switch's ignition power source?
  7. Aug 8, 2011 at 9:51 AM
    Pugga
    Massachusetts
    Crap, sorry, I forgot I still owe you a picture :eek: I'll upload a pic when I get home tonight (I took the motorcycle to work today).
  8. Aug 8, 2011 at 9:55 AM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Haha no worries! and thanks again for all of your help
  9. Aug 9, 2011 at 3:22 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Alright guys I ran into a little trouble trying to mount the lights today. The lights I ordered didnt come with any screws or bolts, so I went to a hardware store and got what the guy there recomended. Got home and realized that the hitch is a lot thicker than i thought and I snapped a drill bit trying to put them in. Any of yall have any ideas as to what I could do or what hardware to use?
  10. Aug 9, 2011 at 4:50 PM
    Pugga
    Massachusetts
    Well, I got pictures but I can't find the upload wire!:mad: But, I can explain fairly easily where I connected the power to and unfortunately I don't think my write-up will be of much use to you. If you pop the hood and take off the plastic cap covering the under-hood fuse panel, there's a bolt at the passenger side front of the fuse box. I used a loop connector and connected to that bolt. The wire I used has an in-line fuse. From tracing wires, I pulled power from there which is a constant hot, whether the ignition is on or not. I used that as a constant hot and used relays so the lights can only turn on when the high beams and the switch is on. Because the high beams is the 'switch' and the headlights turn off with the ignition, it's impossible for me to leave my aux. lights on.
  11. Aug 9, 2011 at 4:51 PM
    Pugga
    Massachusetts
    Get a decent drill bit and some self tappers. I'd use stainless steel screws if you can find them and put silicone in the holes before the screws. It'll seal out moisture so the hitch can't rust from the inside out.
  12. Aug 10, 2011 at 7:37 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    finally got the lights mounted after I went and got a titanium drill bit. Also went and picked up all of the wiring stuff I needed.
  13. Aug 10, 2011 at 7:46 PM
    rolltide3705
    A.J.
    Birmingham, Alabama
    Alright another quick question. I modified the diagram a little bit and kind of combined it with the one posted from TTORA on the last page. Will this still work? Again with the black box being an in-line fuse.
  14. Aug 11, 2011 at 5:09 AM
    Pugga
    Massachusetts
    That would work and your switch would be a constant hot, regardless of whether the truck is running or not. You could move the fuse closer to the battery so you only need one in-line fuse. Split the wire after the in-line fuse and send one to the switch, one to the relay. No need for 2 fuses.
    To save yourself wiring directly to the battery, you could use that bolt in the fuse panel under the hood. Keeps the wiring round the battery cleaner looking if that's a concern of yours.
    I like that mounting set-up, looks clean!
  15. Aug 11, 2011 at 8:18 AM
    #35
    rolltide3705
    A.J.
    Birmingham, Alabama
    Oh ok, I think Ill connect to the bolt in the fuse box. I just got confused when you told me how to do it, i thought that bolt had something to do with the high beams. I must have just mis-read it. Hopefully by tonight they'll be all wired up. Thanks for your help once again.
  16. Aug 11, 2011 at 12:47 PM
    #36
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yes,this will work
  17. Aug 28, 2011 at 11:10 PM
    #37
    davescarp
    davescarp Active Member
    Hudson, MA
    08 AC 4X4 SR5 V6
    Leer cap, spring TSB, bed mat, ventvisors,
    quick question on this, as it is probably going to be on the hit list very soon.. I'm pretty sure I get the wiring on this, but what is the diode all about, and where do I get one?? what are the implications of not using a diode?
