HELP Wiring power for FM modulator
Discussion in 'Audio & Video' started by jpirie, Oct 12, 2007.
  1. Oct 12, 2007 at 4:30 PM
    jpirie
    jpirie [OP] New Member
    '07 Double Cab SR5 4x4
    Im trying to install an FM modulator for my iPod into the radio. I have everything done except for hooking up the power. I am not sure what the best 12v power source to tap into is. Where and what color wire should I look for?
    Thanks!
  2. Oct 12, 2007 at 7:43 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if ur looking for the best power source, i'd run a line straight to the battery. there's a group of cables leaving the firewall in front of the drivers position. run it through w/ it. and what kind of fm modulator are u hooking up that requires a dedicated 12v line vs. a cig adaptor or batteries??
  3. Oct 13, 2007 at 4:28 PM
    jpirie
    its an audiovox mod that bypasses the fm antenna and plugs directly into the back of the stereo. I ran the power straight to the battery and it works perfectly. Thanks!
