Help Wiring Retrofits and other light accessories
Discussion in '1st Gen. Tacomas (1995-2004)' started by PaytonN, Oct 11, 2014.
  1. Oct 11, 2014 at 1:01 PM
    PaytonN
    PaytonN [OP] Well-Known Member
    Payton
    MS
    2009 Prerunner Sport
    I have rgb halos ,devil eyes, and led lights on my bumper
    Could you guys show pictures of you wiring under the hood and mine is a mess
    I want to see how you guys made it more discrete and clean
    I have so many wires I can't even change a headlight with removing the whole housing
  2. Oct 11, 2014 at 8:52 PM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    i just used corrugated wire loom and zip ties for my retrofitted ballast harness/stock harness. follow each wire individually from start to end. wiring just takes a lot of time and patience.
  3. Oct 12, 2014 at 7:15 AM
    PaytonN
    Payton
    MS
    I figured out that I didn't have enough slack in the wires so when I went to put them down they had tension and wouldn't rest on the fender well
    Too bad Id already cut the wires
    Guess I'll learn from that mistake
