Help wiring spyder headlights with parking LED’s
Discussion in '1st Gen. Tacomas (1995-2004)' started by GBall, Nov 30, 2022.
  1. Nov 30, 2022 at 5:54 PM
    GBall
    GBall [OP] Member
    Griff
    2004 Toyota Tacoma
    3” suspension lift/ 32” tires
    Hi, I have a 2004 Tacoma Xtra cab 3.4 liter V6 M/T. I’m installing Spyder Euro Headlights with parking LED’s. I need help with what color wires/ location to splice into to power the LED’s correctly.
  2. Dec 1, 2022 at 6:34 PM
    Bob Haole
    Bob Haole Active Member
    Oahu, HI
    95 Tacoma SR5 Extra Cab 4x4 M/T
    Splice into the corner light bulb wiring. Should be green for positive and white w/ black stripe for ground. This will make those LED's come on with the parking lights. If you want them as DRL's then more wiring will be involved.
  3. Dec 1, 2022 at 8:47 PM
    GBall
    GBall [OP] Member
    Griff
    2004 Toyota Tacoma
    Hi Bob, thank you for your help. The reason I’m confused is that I have blinkers on the corner lights next to the headlights and blinkers on the lower lights in the bumper. Both have 2 wires. Directions said there should be 3 wires with 1 being constant when lights are switched on.
