Help with 1st gen weld on lower shock mount
Discussion in 'Suspension' started by Old green toyota, Jul 28, 2020.
  1. Jul 28, 2020 at 4:33 PM
    Old green toyota
    Old green toyota [OP] Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Where do I place the new mounts for the lower shocks? I have the trail gear ap-306727
  2. Aug 6, 2020 at 7:41 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Did you do it? You’d best to remove the main spring and cycle the suspensión to see where your shocks won’t bottom out at stuff or become a limit strap at droop.
  3. Aug 6, 2020 at 8:17 AM
    Old green toyota
    Sacramento,CA
    Oil leaks
    When I stopped by all pro off road. One of the guys in the office had just done his. I took my eye-crometer out to his truck and figured out where he welded his mounts.
    It's been great so far, the truck rides much better with the new suspension. The rear springs squeaked a little at first.
    Dalandser likes this.
