Help with 2000 2.7 skipping
Discussion in '1st Gen. Tacomas (1995-2004)' started by 17tacostormtrooper, Mar 21, 2018.
  1. Mar 21, 2018 at 3:26 PM
    17tacostormtrooper
    17tacostormtrooper [OP] They call me bacon!!
    Zach
    Pike county Ga
    2017 TRD DCLB/2000 ext cab trd
    Stage 2 icon lift 285/55r20 toyo rt tires Fuel maverick 20x9 wheels Window tint Vent shades LED interior lights Led reverse light Night light rear led standalone reverse lights Smitty built drivers side mole gear seat cover Husky floor mats Truxedo bed cover Factory roof rack Custom grill
    2000 Toyota Tacoma 2.7 L4
    5 speed 180,000 miles
    Has 2 coil packs with spark plug wires
    I am having a slight hesitation issue with my truck! At idle you can barley hear it running some what off but I am very anal about my stuff! Once you get on the throttle it sometimes skips slightly like not firing right or something. It’s seems to skip at lower rpm like around 2000-3000. When you rev it up it doesn’t seem to be skipping! If I fill up the tank with gas it’s doesn’t seem to change or run tank to empty! I need help this truck is about to drive me crazy! If I wasn’t so anal I wouldn’t even worry about it!
    I am going to have a friend of mine check my valaves. The only thing else I Know to do is replace injectors and fuel pump!!!
    NO CHECK ENGINE LIGHTS
    I have replaced the following
    Battery
    Factory denso spark plugs
    Have replaced them multiple times to see if any change to no avail!!
    Ngk performance wires
    New denso coil packs
    Mass air flow sensor
    Egr modulator
    Egr valve
    Pcv valve
    All hoses
    Coolant sensor
    Cleaned throttle body
    New throttle positioning sensor
    New idle air control valve
    K&n filter
    Fuel filter
    Front oxygen sensor
    Cat had been busted out with rear sensor fooler by urd
    Exhaust header
    All exhaust leaks fixed
    All parts have been done in last 6 monthss!!!!!!!!!!!!!!!!!
    I am sure I have left out something I will add to list if I remember!!!!!!!!
    I only run 93 octane in every tank! I have also run my tank until empty to make sure no water! I have ran seam foam, Royal Purple injector cleaner, I have sea foamed the engine!! no abnormal engine sounds like knocking etc.... no leaks or smoke, no burning oil or coolant!
    Please help if you can thanks guys any good I input is wanted!!!
  2. Mar 21, 2018 at 3:42 PM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2002 Tacoma 3.4 v6 Prerunner
    Have you ever replaced the fuel filter?
  3. Mar 21, 2018 at 4:10 PM
    eon_blue
    Azusa, CA
    How empty do you ruin your tank every time? Running it dry repeatedly will fry out your fuel pump
    Brie and 17tacostormtrooper[OP] like this.
  4. Mar 21, 2018 at 4:30 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    crank position sensor?
  5. Mar 21, 2018 at 4:51 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    Sorry yes less than 6 months ago
    Added to list....
  6. Mar 21, 2018 at 4:52 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    No I haven’t can that cause skipping and woukd a cel show up if it was bad!
  7. Mar 21, 2018 at 4:54 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    I just did it a few tanks ago just to make sure there wasn’t any water in there! Only one time lol!
  8. Mar 21, 2018 at 5:17 PM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    ok if your referring to " Skipping" as a rapid misfire, then yes it could, but it is possible for a sensor on its way out to momentarily loose pickup signal and cause this. make sure all your plug boots are seated properly on the cap as well. I had a loose insert once inside the boot and cause this exact issue. you could also have a injector on its way out, but it doesn't sound like a fuel issue. Valves out of adjustment are not going to cause this issue either. my 3rz is on 190k and I have never been done.
  9. Mar 21, 2018 at 5:33 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    How are your mpg has it decreased, does your truck feel weak accelerating at low rpms, or have trouble going past 70-75mph? Or maybe your engine revving sounding louder then it should be (can also seem like your engine is sounding loud close to the intake of the vehicle instead of the overall engine - specific for the 2.4/2.7 engines) in comparison to how much acceleration your actually achieving.
    These are all symptoms of a old fuel filter. Not sure thats your issue or not though going off what your saying, but I'm not sure I understand what your meaning by skipping.
  10. Mar 21, 2018 at 6:47 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    Skipping, misfire, hesitation or like a slight jerking! I will check into my wires more!
  11. Mar 21, 2018 at 6:54 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    Fuel filter was just changed less than 6 months ago! When I accelerate sometime it does cut out or I do experience slight power loss! Engine sounds normal other than you can hear in my exhaust a skipping sound when it starts acting up!
  12. Mar 21, 2018 at 6:54 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Leak down test before anymore parts bazooka
    b_r_o and 17tacostormtrooper[OP] like this.
  13. Mar 21, 2018 at 6:56 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Wise words.
    Sounds like a burnt valve/seat to me if everything else is in good condition
  14. Mar 21, 2018 at 6:57 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    I will have my buddy do all those test I cant. I am not leaking any coolant or burning any oil, I have monitored it for months it’s been doing this crap!!!!!
  15. Mar 21, 2018 at 6:58 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    I sure hope not but I will have all that checked ASAP since she ain’t my daily!
  16. Mar 21, 2018 at 7:15 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Typically a burnt valve won’t manifest itself in any other way but an occasional skip. Especially on cold start it will be more consistent. Have you ever had the valves adjusted?
  17. Mar 21, 2018 at 7:19 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    No I haven’t but I know I should have right after I bought it. I plan on getting it done this week if my guy can get to it!
  18. Mar 22, 2018 at 10:59 AM
    17tacostormtrooper
    Zach
    Pike county Ga
    Getting the camshaft senor now and factory coil pack will see what happens!!
  19. Mar 22, 2018 at 1:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Take the oil cap off, park a new truck underneath it, put oil cap back on
  20. Mar 22, 2018 at 3:26 PM
    17tacostormtrooper
    Zach
    Pike county Ga
    About ready to swap the engine to a Cummins 4bt or a tundra v8 lol:mudding:
    Swap the cam sensor out what a bioch!!! Swap the coils out with factory denso ones not parts house crap!! Have to take her out for a ride tom and see how she does!!
