help with 2001 oil change
Discussion in '1st Gen. Tacomas (1995-2004)' started by DIY rookie, Nov 1, 2011.
  1. Nov 1, 2011 at 4:32 PM
    DIY rookie
    DIY rookie [OP] New Member
    spencer
    florida
    01 nothing fancy
  2. Nov 1, 2011 at 6:29 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    watch this video so you can get a visual on what you'll be doing. it's not the same year truck, but the steps are pretty much the same. just make sure when you unscrew that old oil filter that the old gasket comes off with it.
    http://www.youtube.com/watch?v=NXdrNF3LY3c&feature=related
  3. Nov 1, 2011 at 7:38 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    some tips:
    Use a plastic bag or trash bag under the oil filter when you remove it, it will spill EVERYWHERE because its upside-down.
    Make sure the old gasket comes off when you remove the oil filter
    Get a nice funnel...and keep it in a plastic bag between changes so it doesn't get dusty/sandy.
    Get some nylon washers for the drain bolt, the one that comes off will be dried out and cracked. The torque spec for the drain bolt is 25 ft/lbs
  4. Nov 1, 2011 at 7:48 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    ^X2
    Another tip:
    -Put a little grease or oil on the new oil filter gasket so it hand tightens nicely.
    -Take the oil fill cap off before draining the oil. It will drain the old oil quicker and remove any sediments fast.
    *Edit ^ already in the video
