HELP with 2013 Tacoma air only blowing on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheoJoe, Jan 29, 2023.
  1. Jan 29, 2023 at 5:25 PM
    TheoJoe
    TheoJoe [OP] New Member
    Theo
    2013 Blue Toyota Tacoma
    Hi,
    I recently became the owner of a 2013 Tacoma and I’ve ran into an issue with the A/C unit. The air will only turn on when I flip the switch to the highest setting. Nothing happens on any of the lower settings. I bought a new connector and resistor and installed them both, but there was no change. Strangely, the air conditioning still was working when the connector was unplugged (the blower motor and resistor weren’t connected to each other). Does anyone know why this is, and what I can do to fix it? Thank you so much!!
  2. Jan 29, 2023 at 5:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Jan 30, 2023 at 2:46 AM
    TheoJoe
    Theo
    Hi,
    the issue is that I replaced the resistor and connector already and it still isn’t working. I’m also confused because the A/C keeps going even when the resistor isn’t plugged in.
  4. Jan 30, 2023 at 6:22 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Get you a test light and check the blower circuit as outlined in the link @TnShooter posted.
    TnShooter likes this.
