Help with 2015 trd offroad lift!
Discussion in 'Suspension' started by Rstiltner0116, Mar 17, 2015.
  1. Mar 17, 2015 at 2:15 AM
    Rstiltner0116
    Rstiltner0116 [OP] Well-Known Member
    Georgetown ky
    17 DCSB 4X4
    Truxedo truXport tonneau cover, front air dam removed, to be continued
    Needing some advise on a good 2" lift. I originally had planned on just getting some bilstein 5100's and setting them at 1.75 as a leveling kit for the front. BUT I've been searching around and I've read that the TRD OFFROAD package has progressive coils. And many have said preloading these with the 5100's makes it ride rough as hell. More so than the trd sport suspension with billies at 1.75 So it looks like I'll be getting some coils. What would you recommend or what are you running? It's a 2015 double cab short bed 4X4 I'd like to stay just under 2.5 (1.75-2.25?) because I can't afford UCA's and I want to keep a factory alignment or as close as possible while maintaining a smooth as possible ride. (I have a baby in the truck most of the time) ive looked at eibachs and ome 884's but some have said with a double cab 4x4 the eibachs and ome 884's usually just give about 1.5" lift? Pics of what your running if you have the trd offroad would be awesome
  2. Mar 17, 2015 at 6:34 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Budget?
  3. Mar 17, 2015 at 6:41 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    I'd just save for icon stage 1 with UCAS. That's what I did and I'm glad I did
  4. Mar 17, 2015 at 7:05 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Here's mine with Billies all around, 884x's, wheelers progressive AAL (left overload in to keep the rake), 1/4" driver side spacer, LT 265/75/16C toyo open country at2. I wound up with 2" all around. Rides wonderful. Alignment is good. No need for uca's.
  5. Mar 17, 2015 at 11:14 AM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    That's a great looking truck man. I'm guessing you set the bullies at 0? I'm not a fan of rake personally. I'd like to stay 1/2 or less as far as that goes. So could I just remove the overload leaf when I install an AAL? By the way is yours 4x4?
  6. Mar 17, 2015 at 11:15 AM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    I'd like to stay under $700 for the lift
  7. Mar 17, 2015 at 11:17 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    This is what I did:
    http://www.tacomaworld.com/forum/suspension/357147-general-90-297hd-4-leaf-packs.html
    2" all around, about $1000 if you factor in the alignment and having Wheeler's assemble the coils onto the front 5100s.
    EDIT: Noticed you want to level it. That will not, especially with the short bed. Mine maintains the factory rake which I like so it sits level if I load it. I expect it would be perfectly level on a long bed with a cap.
  8. Mar 17, 2015 at 11:41 AM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    I was planning on only leveling it at first but I've decided to try to get 2" in the front and about 1-1.5 in the rear. I'd like as little rake as possible doesn't have to be perfectly level. It just has too much from the factory IMO. (1.75) higher in the back
  9. Mar 17, 2015 at 11:43 AM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    I was planning on only leveling it at first but I've decided to try to get 2" in the front and about 1" in the rear. I'd like a little rake.doesn't have to be perfectly level. It just has too much from the factory IMO. (1.75) higher in the back
  10. Mar 17, 2015 at 12:02 PM
    js312
    Joe
    New England
    5100s and OME 884s will get you exactly 2" in the front on a V6 4x4.
  11. Mar 17, 2015 at 2:00 PM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    Ok guys one question, I've been on wheelers offroad.com and they have the ome 2884 coils. Is this the same Coil were talking about? Also a few people on the forum have mentioned an ome 884x? What is that?
    Last question. Could I use the stock trd offroad shocks in the rear with a 1" block?
  12. Mar 17, 2015 at 5:46 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Thanks. Yes, billies at 0 and it's 4x4. Removing the overload would put you at 1.5" in the rear rather than 2
  13. Mar 17, 2015 at 5:54 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    The ome884x is what we are referring to. That's what is listed by wheelers. All the new 884 coils are the x version. The old ones have been phased out due to a sagging problem. At least that's my understanding. You can get that setup within your budget. Member Anzy has the 884s cheaper than anywhere including wheelers. Using a block will make it ride like hell. Not sure if it would work with stock shocks or not.
  14. Mar 18, 2015 at 4:55 AM
    js312
    Joe
    New England
    Yup, mine from wheeler's had a label on them that said 884x if I remember correctly.
    I wouldn't use a block either. I'm a fan of replacing the whole leaf pack but an AAL is fine too especially since your stock leafs are pretty new.
    I believe the stock shocks are okay for up to 1.5" of lift (same as 5100 rears).
    By the way, this is mine with the 884s in the front, 5100s all around, and the General HD leaf packs. Overall a similar setup to rngr, and we even both have pyrite mica trucks:
  15. Mar 18, 2015 at 5:26 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    That's funny, your truck is what made me go with this set up. Saw yours and loved it. Turned out even better than I had hoped. Thanks.
  16. Mar 20, 2015 at 8:18 PM
    chitowntaco
    chitowntaco Well-Known Member
    Robert
    Chicago
    2015 DCSB TRD Sport
  17. Mar 21, 2015 at 1:43 AM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    I've heard a lot of people getting the carrier bearing vibes after installing an AAL. I'm kinda paranoid about it. Did you get the vibes? Or did you have them before the lift? I also seen a carrier bearing drop bracket that has like a 95% success rate. Heard of it before?
  18. Mar 21, 2015 at 2:50 AM
    Tractorman
    Tractorman Just A Dumb Farmer
    Stupid
    Misery
    2015 DCSB / MGM
  19. Mar 21, 2015 at 12:52 PM
    Rstiltner0116
    Georgetown ky
    17 DCSB 4X4
    That sounds odd from what I've heard about it. Was it the beefed taco cb drop bracket?
  20. Mar 21, 2015 at 1:37 PM
    Alfred
    Alfred
    California
    My cb drop kit made vibes worse for me also, but I just left the 3 degree Axel shims and the vibes are still there but only at take off and sometimes I don't notice vibration. without shims it would vibrate a lot more at take off.
