Help with 2015 trd offroad lift!
Discussion in 'Suspension' started by Rstiltner0116, Mar 17, 2015.
  1. Mar 21, 2015 at 7:12 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I did not install a CB drop because I did not get any vibes from the lift. It's not just AALs that can cause vibes. Any method of lifting the rear( AAL, block, leaf pack) can cause vibes because it changes the angle of the drive shaft. My advice would be to lift however you want and drive. If you get a vibe, add the CB drop. If you don't, keep driving and enjoy.
  2. Jun 2, 2015 at 3:35 PM
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    I have a 14 dcsb trd fist set up was with the Billy's set at 1.75. Noticed it felt kind of harsh on the road feeling every bump and sometimes pulling my steering wheel. I will add it did level my truck to al,out perfect with the front being .5" higher. I recently in the past couple days put on ome 884 with trim pack and the Billy's set back to zero and it gave me just about the same amount of lift up front. And I must say the ride quality is 100 times better than before! If I had it to do over again I would have just went with the ome 884 with stock shocks the first time since the sport comes with the upgraded shocks anyway. But there is my .02. Hope this helps anyone looking to lift the front or at least just to level it out. I guess I should add I do have the 3+1 leafs in the back but I am not happy with the factory leafs Toyota haves to offer. Any load on them and they sag!
    Wanted to add the pic on my avatar was with the Billy's set at 1.75 with factory springs.
