Help with 3 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bsptacoma, Aug 26, 2017.
  1. Aug 26, 2017 at 1:05 PM
    bsptacoma
    bsptacoma [OP] New Member
    2008 TRD Sport Access Cab
    I want to install a 3 inch strut spacer, or either bilstein 5100s. What would be easier to do by myself?
  2. Aug 26, 2017 at 1:06 PM
    bsptacoma
    And I would also get new coils with the 5100s
  3. Aug 26, 2017 at 1:12 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What equipment do you have? A spacer will be easier to do but you still have to take apart quite a few things and get the vehicle aligned
  4. Aug 26, 2017 at 2:24 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Spacer easier for sure.
  5. Aug 26, 2017 at 3:02 PM
    bsptacoma
    I have a shop. I’ve never done a lift kit before. Was just trying to figure what could be done if I put 1 Saturday away to do it
  6. Aug 26, 2017 at 6:22 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    5100s are super easy to install. You could literally have both sides done in 2-3 hours if your handy. Here is a quick and safe way to do the 5100s without using a spring compressor. It's the best way to do it. I've done it on my last 2 tacomas.
    Don't mind the disclaimer in the beginning.
    DustStorm4x4 likes this.
  7. Aug 26, 2017 at 8:58 PM
    bsptacoma
    Thanks for the help. I believe I’m going to for the 5100s
    nizzmont likes this.
  8. Aug 26, 2017 at 9:05 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you want to make it really easy you can order the 5100s with springs fully assembled so it's a simple pull and replace.
    bsptacoma[OP] likes this.
  9. Aug 26, 2017 at 9:06 PM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    there the best bang for the buck for starting out,im thinking about going with the new 6112 on my new truck maybe,give Marie at Headstrong affroad a call or message on ehre and she can hook you up.
