Help with 3" suspension lift!!!
Discussion in 'Suspension' started by cgilbane, Aug 25, 2009.
  1. Aug 25, 2009 at 10:07 AM
    cgilbane
    cgilbane [OP] Well-Known Member
    Avon, CO
    07 Tacoma dbl cab
    remote reservoir fox shocks front and rear
    I have a 2006 double cab Taco with 48,000 miles on it. I want get a 3" suspension lift.
    I have been looking at getting Fox 2.5" Coil-Over Shox with remote reservoir for the front and back.
    What else do I need to get in order to lift this amazing truck 3"?
    I am not sure if I need to buy new brake lines/brakes?
    Should I get new upper/lower control arms?
    Can 33" tires fit on our Taco's with a 3" lift without rubbing? Or should I go with 32"?
    What I want is more ground clearance, still a nice ride on the streets and highways, but I also do a small amount of offroading in Colorado so I want to be prepared for that.
    Money is not an option because I have a lot saved up for this from an accident I had a year back.
    I want to have a badass, super comfortable ride. Please TACOMAWOLD, help me pimp my ride!!!!
  2. Aug 25, 2009 at 10:12 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    :popcorn:Dude, I want to do the same, so I want to know also!!
    (I'm also looking at the Fox 2.5" Coil-Over Shox)
    O.k. guys point the way.....
    Oh buy the way Welcome to TW Cgilbane!!!
  3. Aug 25, 2009 at 10:14 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    thanks buddy! hopefully these guys will help us out! SHARE YOUR GENIUS WITH US!
  4. Aug 25, 2009 at 10:18 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    33's will require some trimming to fix rubbing problems. How much depends on what else you do. If you get rims with a better offset (Like 0- to -12 offset with 4.5inch backspace) you'll have to trim a bit. You can also add spacers to the stock rims to make the extra clearance.
    UCAs are a VERY good idea if you are going to 3 inches. Folks have had luck with getting a good alignment with the stock UCAs but aftermarket ones will make it easier and provide extra clearance for those 33s.
    New brakes/brake lines are a good idea if you've got extra money to burn...Not really required. if you are going to get into off roading alot more...rear lines are a good idea to not over extend the stock ones...but even then...not required.
    Think I hit all your questions...Welcome and good luck getting your rig built....
  5. Aug 25, 2009 at 10:18 AM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    You dont have to get UCAs but it is never a bad idea. The Fox coilovers will be awesome! You can run 33's. You might have to trim a little plastic but it is no big deal at all. Your brakes and lines will be fine.
    You could always get the 4" lift Spindles from Camburg. They cost a bit but you will have an amazing ride.
    Welcome to TW!!!!
  6. Aug 25, 2009 at 10:19 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Search the sususpension forums...there are tons of info out there.
    Get the UCAs for 33s if you have the cash and moto metal rims and Nittro grappler 285/70s
  7. Aug 25, 2009 at 10:21 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    i really like BFG all terrain tires. everyone out in CO who I see out on the trails seems to drive them. What do you guys think?
  8. Aug 25, 2009 at 10:22 AM
    rob1
    Robert
    South Texas
    Thanks for the info guys and sorry I forgot to check the suspension forum..:smack::rolleyes:
  9. Aug 25, 2009 at 10:23 AM
    imsikotic
    Randy
    Temecula, Ca
    BFG Km2s are sick as hell!!
  10. Aug 25, 2009 at 10:25 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    but would I want to run mud terrain's when I do mostly driving on the highways at around 80 mph, and I offroad, but only on the weekends
  11. Aug 25, 2009 at 10:28 AM
    imsikotic
    Randy
    Temecula, Ca
    Thats what I have. I like having them when i need 'em. I dont get to go offraod as much as Id like but the tires are great and they are quiet on the freeway.
  12. Aug 25, 2009 at 10:29 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    is there any vibration on the highway at high speeds since they are mudders? also how are they in snow and rain and ice?
  13. Aug 25, 2009 at 10:36 AM
    imsikotic
    Randy
    Temecula, Ca
    No vibes. They are fine in what rain we get in San Diego. "Snow and Ice." What is that? I dont know those terms. Im sure some of the other guys do though.
  14. Aug 25, 2009 at 10:48 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    hahaha true you prolly dont get much of that in your neck of the woods. I spend most my year in snow and ice and mud out here in Colorado.
    So if I get new:
    *upper control arms
    *Fox 2.5" Coil-Over Shox with remote reservoir for front and back
    *33 inch tires (what is the best size rim for highway driving with a little offroading?)
    *brake lines
    *brakes
    I should be good to go? any other things im forgetting that would be good to replace after I lift 3"?
  15. Aug 25, 2009 at 10:50 AM
    rob1
    Robert
    South Texas
  16. Aug 25, 2009 at 11:01 AM
    imsikotic
    Randy
    Temecula, Ca
    What size rims are you running now? I wouldn't go over a 17x9" wheel. You can run a 285/70/17 tire.
    Wheel Specs: 17x8 or 9
    4.5inch backspacing
    -12 offset
  17. Aug 25, 2009 at 11:03 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    not positive on what size my rims are. I have a stock 2006 double cab trd sport package.
  18. Aug 25, 2009 at 11:08 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    i believe the sport package runs 17" rims stock
  19. Aug 25, 2009 at 11:13 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    It does the OR has 16s :D
  20. Aug 25, 2009 at 11:16 AM
    imsikotic
    Randy
    Temecula, Ca
    If its a Sport it has 17s.
