Help with 4wd to 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreenMountainBoy, Aug 26, 2012.
  1. Aug 26, 2012 at 3:19 PM
    GreenMountainBoy
    GreenMountainBoy [OP] Member
    Gary
    Vermont
    2012 Tacoma 2.7L 5spd. Manual
    Ive had my new 2012 Tacoma for a while now and have just tried out the 4wd to make sure everything works. Seems like when I go from H2 TO H4 everything works fine but when I go to L4 I have a hard time getting it out of L4 back into H2. At one point it felt like my ebrake was on. So here I am just about stuck in the road with traffic coming buzzer sounding, lights blinking and trac light on and it won't come out of 4 low. It's my first 4wd what am I doing wrong? How come there isn't a smooth transition from low 4 back to H2?
  2. Aug 26, 2012 at 3:25 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Are you driving on pavement in 4wd? Please say no.
  3. Aug 26, 2012 at 3:29 PM
    GreenMountainBoy
    Gary
    Vermont
    Yes pavement is where I tested.
  4. Aug 26, 2012 at 3:30 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    If your truck is beeping your not in 4 low
  5. Aug 26, 2012 at 3:31 PM
    jandrews
    '09 FourDubDee TRD OR
    I'm just here to watch.
  6. Aug 26, 2012 at 3:33 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Do not run 4H or 4L on pavement.
  7. Aug 26, 2012 at 3:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Shut the truck off, turn the switch to 2H restart and back up.
  8. Aug 26, 2012 at 3:35 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    are you at a complete stop or under 5mph before you turn the dial from 4L into H2?
  9. Aug 26, 2012 at 3:35 PM
    GreenMountainBoy
    Gary
    Vermont
    Could have been my seat belt alarm. Not sure it was on. Whats up with the feeling like my ebrake is on when it isn't?
  10. Aug 26, 2012 at 3:35 PM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    Testing on a straight stretch of pavement is ok but I wouldn't do it too much. Please don't cruise around in 4wd on pavement though. :facepalm:
  11. Aug 26, 2012 at 3:36 PM
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
  12. Aug 26, 2012 at 3:36 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    That's 4L
  13. Aug 26, 2012 at 3:36 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    First off never drive with the 4wd engaged on pavement (see links below.) Anytime you make a turn things will bind up and eventually break. To get out of 4lo you need to get back into 4hi...then you can get back into 2wd. When you make the switch from 4hi back into 2wd take your foot off the gas pedal...then turn the knob. Doing that will take the load off the driveline and you won't get the "clunk" noise.
  14. Aug 26, 2012 at 3:37 PM
    MonkeyProof
    SoCal- SGV
    4wd wont hurt on dry pavement unless turning sharp radius's..in my opinion anyways :p
  15. Aug 26, 2012 at 3:37 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    4wd is probably binding up since your on pavement. Does the truck beep at you when you have the dial on 4H?
  16. Aug 26, 2012 at 3:38 PM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    yea 4L is a super low gear so it wont roll when you take your foot off the brake
  17. Aug 26, 2012 at 3:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    But not a good habit to get into because one WILL forget.
  18. Aug 26, 2012 at 3:40 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  19. Aug 26, 2012 at 3:40 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Do you feel like your ebrake is on when you are turning? That would be your trucks drivetrain binding in 4wd. DO NOT drive the truck on dry pavement in 4wd, especially if you are not going in a straight line. Please read the link below before you drive in 4wd again.
    http://www.majormedia2.com/4WDSimplifiedv5/4WD.html
    http://4x4abc.com/4WD101/definition_part.html
    http://www.4x4abc.com/4WD101/axle-wind-up.html
    http://www.4x4abc.com/4WD101/def_turnpart.html
    http://auto.howstuffworks.com/four-wheel-drive.htm/printable
  20. Aug 26, 2012 at 3:43 PM
    GreenMountainBoy
    Gary
    Vermont
    Thats when the ebrake feeling started when I tried to turn truck. I don't plan on driving 4wd on pavement unless the roads are snowcovered and I need it. I was just testing it and saw nothing in the manual about useing it on pavement. So what Im getting is that this is normal and test it off road.
