Help with 4wd to 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreenMountainBoy, Aug 26, 2012.
  1. Aug 26, 2012 at 3:44 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    guilty!!!!
    i once drove from Lytle Creek all the back to Monrovia in 4H. averaging 80-85mph on the 210. didn't notice until i pulled into a parking spot at my local Starbucks and was thinking what the hell was that binding when i was turning into the parking spot :facepalm:
  2. Aug 26, 2012 at 3:45 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    When you stop to go from 4L back into 4H remember the clutch pedal needs to be ALL the way down. Going from 4H back into 2WD can be done on the move.
  3. Aug 26, 2012 at 3:46 PM
    MonkeyProof
    SoCal- SGV
    i love my automatic :p
  4. Aug 26, 2012 at 3:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I spent my first 2 weeks with my 2.7 running in 3rd instead of "D"
  5. Aug 26, 2012 at 3:57 PM
    jandrews
    '09 FourDubDee TRD OR
    This is normal but BAD. Binding + low gears = broken drivetrain. Quickly. 4wd is for low-traction surfaces only. Driving in a straight line is much less stressful for your vehicle but still not ideal.
    In your defense, this is a warning the owner's manual really should have and doesn't. Toyota, in their adorable ignorance, assumes American truck buyers will know enough about 4wd not to destroy it after purchase. Precious.
    x2. But it ain't got shit to do with ease of 4wd use...I love the torque converter tricks!
  6. Aug 26, 2012 at 4:03 PM
    GreenMountainBoy
    GreenMountainBoy [OP] Member
    Gary
    Vermont
    2012 Tacoma 2.7L 5spd. Manual
    Thanks, people I think I got it. Toyota manual does have most of this in there. Should have took more time to read. Hope I didn't hurt it.
  7. Aug 26, 2012 at 4:26 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You're not alone, I started a similar thread shortly after I got my truck! Luckily there's smart people on here to help us.
  8. Aug 26, 2012 at 4:40 PM
    jandrews
    ToMoCo could've done a better job with it.
    It's been a while, but I remember something to the effect of "use 4wd in slippery conditions" and "don't use 4wd during normal driving conditions as it may cause unsafe handling and braking".
    What they really need is that, plus, in big red 18 point font:
    ATTENTION NOOBS: DO NOT OPERATE PART TIME 4WD SYSTEMS ON HIGH TRACTION SURFACES SUCH AS PAVEMENT. YOUR TRUCK GON' BLOW UP.
    Or something to that effect.
  9. Aug 26, 2012 at 5:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The problem is that the manual is 400 pages.
    300 pages are in 3 languages not native to the owner.
    Of the remaining 100 pages, 50 of them are in a language native to product liability attorneys, and 30 of them are 3rd-grade level drawings indicating things such as "Do not close the hood while your head is over the engine" and "Do not start the engine while holding your dick against the fan belt"
  10. Aug 26, 2012 at 5:46 PM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    :rofl:
  11. Aug 26, 2012 at 6:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I understood it... it was just so repetitive and boring that it was hard to read.
    It was like doing a book report for an upper division college class on "Green Eggs and Ham"
    Oh wait... our educational system might be at that level by now.
  12. Aug 26, 2012 at 6:23 PM
    Larry
    Larry CARL
    CARL
    I couldn't sleep one night and read the entire thing.
    I'll admit to not reading it word-for-word, but I did go through every page.
  13. Aug 26, 2012 at 7:17 PM
    Gerry Pope
    Gerry Pope Well-Known Member
    San Diego
    07 4X4 PreRunner
    Sad but true.
    Thanks for the chuckle...
  14. Aug 26, 2012 at 7:20 PM
    Fury
    Fury Well-Known Member
    Hi all.
    1 - You must stop and have your manual trans out of gear or have the clutch disenged to switch in or out of L4
    2 - I wouldn't switch from H2 to L4 or back - go to H4 then continue with a second switch.
    3 - You can drive on dry pavement in 4WD ...
    - only do it as a test or for your monthly 4WD engagement if you have to.
    - Use very little throttle and don't turn sharp if you are doing your monthly engagement, under 100 kph in H2..
    - Go slow and don't force the steering wheel further than when a slight binding is felt if you are doing a parking lot test to make sure 4WD is engaging.
    - Don't switch to L4 monthly - only in a parking lot, following the rules above, if you need to test it is actually working.
    - I have only tested my truck once when it was new and will repeat only after any work is done on the 4WD system.
    - I always put my truck back into H2 before parking it anywhere, anytime, even if I know I will be using H4 the next time I will be driving. This prevents you from accidentally leaving it in 4WD.
    Of course you can always take your truck offroad instead if your concerned about dry pavement.
    Cheers
    Ray.
  15. Aug 26, 2012 at 7:31 PM
    #35
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    FWIW, the owners manual says to drive the vehicle in 4wd at least 10miles a month to ensure lubing of the front wheel drive components....
    I would hope people know to find a dirt road for this, Lol...
  16. Aug 26, 2012 at 7:38 PM
    #36
    Greenbean
    Zack
    Western NC
    True, true,
    I was amazed at the binding in 4Lo today on the dirt roads...
  17. Aug 26, 2012 at 7:55 PM
    #37
    jandrews
    I still can't figure out why it says that, since the front diff is always turning and thus always lubing in these trucks, even in 2wd.
    I think the real reason is to keep the actuators from sticking.
  18. Aug 26, 2012 at 7:58 PM
    #38
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
  19. Aug 26, 2012 at 8:03 PM
    #39
    OffroadToy
    :confused: Your recommending engageing 4L in a parking lot?
  20. Aug 27, 2012 at 8:31 PM
    #40
    Fury
    I tested my 4WD in a parking lot on dry pavement - H4 and L4.
    Jeese - my transfer case didn't fall out and my truck didn't blow up ...............
    As I posted ... if you use your head there isn't a problem.
    Very little throttle and only turn the steering wheel enough to feel some binding - less than a half a turn. This isn't even enough to have the tires scrub - which will happen looooong before any metal parts come apart. I only did this to test that the system is actually working. If you are alone it can be difficult to feel that the vehicle is actually in 4WD when offroad.
    This crap going around that states, if you engage 4WD on dry pavement will result in immediate damage is hogwash.
    Cheers
    Ray.
