Help with A/C Drain Valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vintperc, Jun 22, 2015.
  1. Jun 22, 2015 at 1:00 PM
    vintperc
    vintperc [OP] New Member
    Eric
    2011 Tacoma
    Greetings,
    Last month our 2010 Corolla encountered a 'plugged drain valve' from the A/C that flooded our interior and cost $700 to repair and clean.
    With that said, my 2011 Tacoma is now doing what sounds and looks like the same thing.
    Can anyone help with this issue - like a diagram of where the drain valve is, etc...?
    Thanks in advance for your help.
    Eric
  2. Jun 22, 2015 at 3:23 PM
    vintperc
    Eric
    2011 Tacoma
    AWESOME! Thanks. That was easy to find. Just ran a thin twig up the hose and about a pint of water came rushing out.
  3. Jun 22, 2015 at 3:51 PM
    Pigpen
    Dan
    Northwest Montana
    What symptoms were you experiencing?
  4. Jun 22, 2015 at 4:01 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    If you have a blocked tube, try blowing some air from a compressor or compressed air into the drain tube from under the car.
  5. Jun 22, 2015 at 6:03 PM
    vintperc
    Eric
    2011 Tacoma
    58 Siesta - had a small drip from underneath the glove box onto the passenger side floor mat. Our Corolla had a hissing sound like a hot iron touching water whenever we turned. Noticed a little water on the passenger side floor until one evening after my wife came home from work. It flooded the passenger side front and back seat floor board.
    03coma - I saw that on a youtube video from ericthecarguy.com. The water flowed out of my Tacoma drain tube just like it did in his video.
  6. Jul 2, 2015 at 6:35 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    Good job vintperc, the smallest thing can clog that tube, spider webs, dirt ect.
