Help with a couple questions (New Tacoma Owner)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rarrrrrr, Oct 16, 2010.
  1. Oct 16, 2010 at 8:32 AM
    Rarrrrrr
    Rarrrrrr [OP] Member
    Seattle
    2011 DC TRD OR - MAG GRY
    While these questions seem silly to me, I had a bit of a hard time searching for these answers.
    1) Does the incessant beeping have to be apart of the 4x4 LOW experience!? Is there a intelligent reason for this? I mean the truck behaves quite different in 4L and has a flashing dash light, so why do I need a beep...?
    2) I am pretty sure that I cannot do an AAL with the stock bilsteins, is that correct?
    Thanks
  2. Oct 16, 2010 at 8:34 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    1) the beeping and flashing means you are NOT in 4lo. you need to come to a complete stop, put shifter in neutral, then flip the switch. if it does not engage you'll need to rock back and forth with the wheels turned sharp left or right
    2) no, that is not correct. you can add an aal and be just fine, your flex will benefit from longer shocks however.
  3. Oct 16, 2010 at 10:15 AM
    Rarrrrrr
    Seattle
    Sweet. Thanks!
