help with a question
Discussion in 'South East' started by nathan parker, Oct 17, 2012.
  1. Oct 17, 2012 at 7:17 AM
    nathan parker
    nathan parker [OP] New Member
    nathan
    richmond ky
    02 tacoma crew cab
    i have a double cab toyota tacoma 2002 all stock, i bought a set of 16 by 8 inch pacer wheels i was wondering if they will fit on my truck because i am about to get some new tires on my truck and wanted to put the new wheels on with the new tires, the wheels on my truck now are a 16 by 7 inch wheel and im running a fierce attitude mt that is 265/75 tire size. so i guess the question is will the 16 by 8 inch rim work?
  2. Oct 21, 2012 at 8:24 PM
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    it should. If you go get the tires installed, ask the shop to put the tire on the rim and test fit it on the front with you standing there. If you like it and it doesn't rub UCA or LCA then you should be good.
    EDIT:
    UCA- Upper Control Arm
    LCA- Lower Control Arm.
    put that there incase you didn't know it already! lol
