Help with aftermarket wiring harness
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steadyeddie1970, Oct 14, 2022.
  1. Oct 14, 2022 at 11:23 AM
    Steadyeddie1970
    Steadyeddie1970 [OP] Active Member
    Ed
    2013 Tacoma Limitee
    Hey guys,
    I have a 2013 Tacoma, I bought it used and it came with an aftermarket headlight and taillight package.
    I believe it's a Spyder Black Projector Headlights, but I'm not sure. Looking for info on the unit itself is daunting. Spyder looks close to what I have, though.
    There's a 3 way plug that goes into the harness. My low beams not working. When I test the resistance on high beam wiring path (red), it's about 6 ohms. low beams (blue), about 290 ohms.
    I'm trying to look on Spyder's web site, but they have very little information.
    They want me to enter part number/SKU, I have none of that information to send them an email and I can't send the form without it.
    At this point, should I just replace the entire headlight assembly?
  2. Oct 14, 2022 at 6:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you have power to the Low Beam fuses?
    Are you using the stock headlight connector?
    Or is it aftermarket?
    Steadyeddie1970[OP] and Dm93 like this.
  3. Nov 2, 2022 at 1:53 PM
    Steadyeddie1970
    Ed
    2013 Tacoma Limitee
    I have power to the fuses.
    I have power to the plugs to the bulbs... It's like I have 12.5 volts, but maybe not enough amps?
    I replaced both plugs.
  4. Nov 2, 2022 at 2:39 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Have you tested the bulbs? Have you tried a known good bulb? Go for the simple stuff first.
