Help with air bag light staying on
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Dec 20, 2015.
  1. Jan 7, 2016 at 3:40 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    lol
    Yeah, that makes sense.
    Fairly amusing the cell phone powers the dash light on its own.
  2. Jan 7, 2016 at 4:01 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Have you checked the sensors under the hood? The one on the frame, drivers side is know to grow corrosion internally.
    Try swapping that one with the 1998. If connections are the same, it will work.
    fouillard13[OP] likes this.
  3. Jan 7, 2016 at 7:20 AM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    It's not a $20 scanner. It's a $2000 OTC scanner. Most scanners will not clear airbag lights. They can read them but not erase.
  4. Jan 7, 2016 at 8:42 AM
    koditten
    Kirk
    Central Michigan
    You don't need any scanner to clear SRS codes. Once you have all connections correct, the ECU will turn off the light.
    You just need to find out which one is not communicating with the ECU.
    The only check the SRS ECU does is check for continuity when you start the truck. All connections and sensors good? No light is turned on.
  5. Jan 7, 2016 at 9:43 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Just looked at my 98 and the module is different
  6. Jan 7, 2016 at 9:54 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Sorry youre right, it looked like an Android tablet you were using. Im used to the Snapon's that are Windows based.
    Im going to see if i can unplug something to trigger this, or maybe plug by battery pack back into the cig lighter, lol, then see if my MT2500 can clear it. Ive been able to do this on BMW's and VW's with no problem.
  7. Jan 10, 2016 at 6:38 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Still have yet to figure this out. Contemplating swapping clock spring
  8. Jan 10, 2016 at 6:58 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Can this be a crash sensor? Truck we never crashed but the sensor could be damaged/unplugged.
  9. Jan 11, 2016 at 3:56 AM
    koditten
    Kirk
    Central Michigan
    That's what I told you earlier. The crash sensor can corrode internally. Try swapping the sensor with your other truck. If the other truck gets a light, you found your problem.
  10. Jan 11, 2016 at 11:15 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Do you happen to know where they are located on the tacoma
  11. Jan 11, 2016 at 11:18 AM
    koditten
    Kirk
    Central Michigan
    Follow the yellow wires. The SRS uses a bright, yellow shiething. Its the only system that uses that color.
  12. Jan 19, 2016 at 11:19 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Checked and everything seems to be intacted. Not sure what to do next. Really don't want to bring to dealer. Can a clock spring be bad and still have horn and cruise work?
  13. Jul 3, 2019 at 8:28 AM
    PVGWhite
    PVGWhite Member
    Greg
    03 TRD 4x4
    Wow, once again you guys have come up with an answer to one of life's many problems. I had found out many years ago that if I left my phone plugged into the lighter outlet overnight, in the morning the phone would be dead. I have since tried not to leave it on the car charger after that. A week ago I left the phone in the wireless charging mount for a few hours, and when I started the truck, the SRS light was on. I disconnected the battery overnight but that didn't work. My ODB reader just reported a "B1100 Airbag Sensor" error, with no further details. I reset the code, and the light has not come back on. Happiness!!
    Speaking of ODB readers, I have one that can read/reset ABS and SRS codes. I am currently in the Tampa area and was wondering how I should go about offering to help with reading those codes for others in the area. Is there a "Help offered" section of the forum?
    Thanks,
    Greg
    Jimmyrace likes this.
  14. Jun 5, 2024 at 3:07 AM
    Billymons
    Billymons Member
    Bill
    2003 Tacoma 4x4
    I know this is oldddddddd! But what did you ever find?
