Help with allpro UCA Ball joint PICS inside.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jimirich, May 18, 2010.
  1. May 18, 2010 at 5:05 PM
    Jimirich
    Jimirich [OP] Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    I've got a 2008 4x4 with Toytech coilovers and Allpro UCAs. Ihad the lift "professionally" installed.
    I've been having noise from the left side and noticed the UCA retention bolt was coming loose. Upon tightening the the UCA arm retention bolt I also noticed that the recessed retention bolt on the left ball was not flush with the top of the ball. note the following pic with it sticking up.
    The other side is flush and looks like this:
    I called Allpro yesterday and I belive the phone jockey at allpro lied and did not show the pictures to the service tech. It was basically a dead end.
    Anyone wanna offer me some info on why this bolt should not be flush like the other side.
    It is completely tightened to the retaining nut underneath and the phone jockey says the bolt threads only into the retaining nut on the bottom. So basically he is saying the nut should slide all the way down till its seated and the retaining nut is the only way the bolt stays seated.
    Also I wonder why the questionable side is all corroded.
    The install is less than a year old.
    Should I get a new ball from Allpro?
    Here's the bottom: all snug
  2. May 18, 2010 at 6:03 PM
    Jimirich
    Hawaii
  3. May 18, 2010 at 6:06 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    take it back to the place you got it professionally installed at
  4. May 18, 2010 at 6:58 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    something is wrong w/ the spacing on the bolt...only way to really know is to take it apart...or take it to the "professional" installer...yet another reason i do all my own work on my truck if possible...
  5. May 21, 2010 at 1:52 AM
    Jimirich
    Hawaii
    For whatever reason the installer put a washer on the left side. Its not worth dismantling just to remove a washer.
  6. May 21, 2010 at 7:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I think it is. THey need to be installed correctly.
  7. May 21, 2010 at 11:06 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I would call All Pro and double check that assumption...
  8. May 21, 2010 at 11:15 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    yea, i dont think case is closed, the head of that bolt seems like it might be able to damage the inside of that cup attached to the arm if you get enough downtravel..but thats just me. (and the two guys above me!):D
    EDIT: also, was there any explanation why there was a washer on only one side?
  9. May 21, 2010 at 11:27 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    Note to self, don't have a "professional" install the UCAs.........
  10. May 21, 2010 at 11:36 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    x2. It's a single nut and bolt that's not hard to remove. Spend the 20 minutes fixing the issue and you'll never have to worry about it again.
