help with amsoil.
Discussion in 'Product Reviews' started by steve103, Oct 20, 2010.
  1. Oct 20, 2010 at 2:31 PM
    steve103
    steve103 [OP] Well-Known Member
    steve
    santa cruz ca
    07 taco
    arb bumper,bilstein shocks,886 ome springs,ar mojove rims,2optima batteries,custom electrial.on board air,cb,14gal frontrunner water tank,frontrunner roofrack
    has any one used amsoil in their 2nd gen. im looking to change all but engine oil to amsoil. ive read that people have had problems with other types of oil other than factory in there rear diffs. thanks
  2. Oct 20, 2010 at 2:34 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Nothing wrong with using Amsoil in the rear differential. I plan on switching to Amsoil in the diff. when the time comes. Make sure you get a limited-slip additive if you have a LSD.
  3. Oct 20, 2010 at 2:35 PM
    steve103
    steve
    santa cruz ca
    07 taco
    no its just 4x4 no trd. but the rear diff is lsd.
  4. Oct 20, 2010 at 2:46 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    You'll be ok. My 07 has Lsd rear diff and these clutch type mechanical setups can be finicky. There will be sticker on back of diff that says LSD oil Only. If no sticker then likely open diff and any oil will work. If your ordering lube from Amsoil know ahead of time what u need and if u have LSD make sure the stuff u get either has additive (friction modifier, LSD additive etc) or order it extra. I would recommend that even if the oil has additive going ahead and ordering an extra bottle to have in case u get any noise or vibes. And if u do only add 1 to 2 ounces at a time with some driving in figure 8s in between until your happy.
  5. Oct 20, 2010 at 2:49 PM
    Airun
    Aaron
    Show Me State
    My 07 sr5 has LSD
  6. Oct 20, 2010 at 3:21 PM
    steve103
    steve
    santa cruz ca
    07 taco
    07 no trd yes to lsd no to aftermarket its stock man.
  7. Oct 20, 2010 at 3:23 PM
    Airun
    Aaron
    Show Me State
    It says right on the pumpkin "LSD oil only"
  8. Oct 20, 2010 at 3:52 PM
    Airun
    Aaron
    Show Me State
    I have talked to other sr5 owners on TW with LSD as well. Apparently they were on some sr5 units and not others. Go figure
  9. Oct 20, 2010 at 4:18 PM
    steve103
    steve
    santa cruz ca
    07 taco
    it has a lsd sticker
  10. Oct 20, 2010 at 4:19 PM
    steve103
    steve
    santa cruz ca
    07 taco
    but still no one has used amsoil? am i reading this right.
  11. Oct 20, 2010 at 8:25 PM
    Airun
    Aaron
    Show Me State
    Nah. Do a search for "beware changing LSD lube" or something to that effect. There were reports of amsoil and redline working good, but not so well with mobil1 and royal purple
  12. Oct 21, 2010 at 6:20 AM
    Airun
    Aaron
    Show Me State
    WTF? .....sticker put there buy mistake?
