Help with audio setup
Discussion in 'Audio & Video' started by scharfy324, Nov 24, 2012.
  1. Nov 24, 2012 at 12:30 AM
    scharfy324
    scharfy324 [OP] New Member
    New Orleans
    08 PreRunner
    Hey guys,
    I have an 08 double cab tacoma and I'm about to do a speaker upgrade with a sub. My plan is to run some 6.5 Hybrid Audio Imagine components in the front with no rears (might get some coaxials to hook up to headunit for backseat riders) and run the Sundown Audio sd-2 10 inch shallow subwoofer behind the seat with a box made by Mr. Marv.
    1. http://store.12velectronics.com/imagine-i61-2v2-6-5-component-coaxial-speaker-set/
    2. http://www.sundownaudio.com/index.php/products/subwoofers/item/sd-series.html
    My question to all of you is what kind of amp/amps should I run with this setup. I really wanted to only have to run one 4 channel amp, running the components on channels 1 and 2 and bridging the other two channels. I found an amp that seems perfect on paper for these subs but idk how good it really is. It's the Hifonics Zeus zrx 1000.4- 125w rms x 4 channels at 4ohms, 500w rms bridged (so it says). I was wondering if this would be a good choice or if I should go with a higher quality class D amp, or just get two amps.
    http://www.sonicelectronix.com/item_44492_Hifonics-ZRX1000.4.html
    If I did have to run two amps, would this be a good set of two?
    1. http://www.sonicelectronix.com/item_34507_Hifonics-HFI1000.1D-HFI-1000.1D.html (For sub)
    2. http://www.sonicelectronix.com/item_17785_Boston-Acoustics-GT-2125.html (for components)
    I'm also more than happy to take other suggestions about any amps you may have in mind, or other speakers or subs you may think are better. I listen to a lot of rock/dubstep and some rap on occasion. I'd appreciate any feedback.
    Thanks!
  2. Nov 24, 2012 at 10:03 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Personally I wouldn't buy hifonics, unless I was on a super tight budget. Always loved alpine amps, solid build, cea rated, and priced decent besides the pdx line, absolutely love the older v12's the sd will take more than 500, obviously, especially in a small sealed box, I had my 1500D running 2 sd2 tens with no problem.
    Other solid choices include sundown,aq....and etc.
  3. Nov 24, 2012 at 10:37 PM
    Highspeed
    Highspeed Well-Known Member
    +42° 52' 21.69", -124° 32' 8.50"
    TRD off road
    A.R.E. cap
    There are tons of good amps out there, too many for anyone to tell you which one's to buy. Since you plan on buying some gear from Mr. Marv I would go with amps he sells. He only sells products he recommends and has a rock solid reputation.
  4. Nov 25, 2012 at 6:17 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    I think he's looking for recommendations. Alot more shitty amps out there than good...
  5. Nov 25, 2012 at 6:24 AM
    LEGITacoma
    LEGITacoma Well-Known Member
    Louisiana
    99 Tacoma Prerunner
    Rockford Fosgate T0 in a Ported Box, Hifonics 1000.1, Pioneer AVIC Z-120BT Headunit w/ Rearview Camera
    Personally I've have an Hifonics amps right now and no it hasn't exceeded my expectations but it has done its job. It's not cea compliant because I didn't even know what that was when I bought it so it is not pushing out what it says.
  6. Nov 25, 2012 at 11:41 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    get a good class a/b amp to run your door speakers.
  7. Nov 25, 2012 at 6:12 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    dbrelectronics.com is the way to go for cheaper, good amps. rebuilt, with warranty.
  8. Nov 27, 2012 at 8:43 PM
    scharfy324
    New Orleans
    08 PreRunner
    Thanks everyone for your input! So I kept searching and I think I found two good amps that I could possibly use for a one amp setup. I think these two amps would work perfect with my setup.
    1. http://www.sonicelectronix.com/item_27729_Massive-Audio-N3.html
    or
    2. http://www.sonicelectronix.com/item_38338_Precision-Power-PPI-P900.4.html#tabs
    These two amps would put out plenty enough power to push my components and a woofer running 400 too 500 rms. Out of these two which would you guys pick? Also, I'm looking for a sound quality subwoofer and not looking for spl so much. Are there any other recommendations for a sub? Besides the sundown sd-2, I was thinking about the IDQ 10 or the Rainbow Hammer. Any suggestions would be appreciated. Thanks!
  9. Nov 28, 2012 at 8:52 PM
    scharfy324
    New Orleans
    08 PreRunner
  10. Nov 29, 2012 at 11:08 AM
    Highspeed
    TRD off road
    A.R.E. cap
    I'm sure you'll be happy with those. I would also pick a class a/b amp to run the fronts but the full range class D are very good.
  11. Nov 29, 2012 at 11:34 AM
    scharfy324
    New Orleans
    08 PreRunner
    Thanks! The massive audio actually has A/B to the two speaker channels and class D to the mono sub channel. I think that's what I'm going to get
  12. Nov 30, 2012 at 7:56 AM
    96Taco
    Alberta
    '04 V8 4Runner
    ..stay tuned
    good choice. keep us updated on your install and give a critical review of your setup once you've had it for a month or so.
