Help with bleeding brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rzimm001, Aug 10, 2010.
  1. Aug 10, 2010 at 9:16 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Just installed my new Camburg lift spindles today along with the Camburg extended brake lines. I went to bleed the brakes after the install and I can't get the air out of the lines. I've already pumped almost a whole bottle of DOT 3 fluid through them and nothing. Brake pedal is still spungy. What do I do? Pump more fluid through them? Thanks
    Edit: Update
  2. Aug 10, 2010 at 9:31 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Are you sure the fittings are tight on the new brake lines? Sounds like air is getting into the system somehow.
  3. Aug 10, 2010 at 9:35 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    Once air is in there you need to bleed the whole system. Start with the back brakes working from the furthest wheel away from the master cylinder then work your way to the front to the closest. Having someone pump the brakes to build pressure then hold them as you open bleeder valve and not to release till the valve is closed. Keep doing it a few times. The back are the hardest to get the air out so make sure to do them more then the fronts. Hope this helps.
  4. Aug 10, 2010 at 10:32 PM
    rzimm001
    Bobby
    Wildomar
    Why would I have to do the rear. Isn't that a seperate circuit or something?
    I wasn't closing the valve when the pedal was released but I didn't see air going back in the line. It did seem to be pump out the fluid quickly. Do you have to close the valve before every release?
  5. Aug 10, 2010 at 10:42 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD OffRoad Poser ψ(`∇´)ψ
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Back brakes still need to be bled, it helped me outt to actually have the truck running as opposed to have it off.
  6. Aug 10, 2010 at 10:47 PM
    rzimm001
    Bobby
    Wildomar
    Okay, if they all need to be bled than how many pumps do I need to do to each corner? What would you consider satisfactory?
  7. Aug 10, 2010 at 11:01 PM
    Series1000
    Series1000 Gots a Taco!
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    3" Redi-lift (spacer lift) up front
    Just to give my opinion, When bleeding brakes with a partner I prefer to do it this way:
    I fill the master with the proper fluid, get some one to pump the brakes ( start farthest from the master RR,LR,RF,LF depending on the set up it may be different) I then yell "pump it up" and the guy inside pumps the brakes 3 or 4 times slow and on the last pump holds the pedal down firmly. At that point they yell "holding" and then I loosen the bleeder to let brake fluid out, just before the fluid stops I shut the bleeder.
    At that point it repeats until I get 3 or 4 good squirts of fluid showing no air. Then I move on to the next wheel until they are all bled. (After each wheel top up the master. Also note brake fluid is corrosive to paint, but as it is hygroscopic (absorbs water) it washes away with a garden hose easily.
    Remember to only use brand new clean brake fluid of the same type as some don't mix. As stated above brake fluid absorbs water (water causes interesting problems) use only brake fluid thats new-with in six months old and only if its had the cap on tight the whole time its been stored.
  8. Aug 10, 2010 at 11:10 PM
    rzimm001
    Bobby
    Wildomar
    Is it a bad thing to re-use any of the old fluid that gets pumped out? I know its sounds stupid but I just bled the brakes not that long ago and the fluid coming out looks brand new. Seems like a waste but maybe that's just how it goes.
  9. Aug 10, 2010 at 11:31 PM
    Series1000
    Vancouver Canada
    Yup, bad idea. Brake fluid is cheap man, and think about it - it has a ton to do with stopping or smashing 30k worth of truck.
    Just buy more
  10. Aug 10, 2010 at 11:55 PM
    rzimm001
    Bobby
    Wildomar
    Alright I'll just buy some more fluid. On a positive note these spindles look freakin bad A$$. I love the fact that I have droop travel again. No more pogo stick feeling either!
  11. Aug 11, 2010 at 12:26 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Ho was the install? Any problems? I got some and was thinking of doing it myself.
  12. Aug 11, 2010 at 8:29 AM
    rzimm001
    Bobby
    Wildomar
    It's definitely a project you can do yourself but it will take the better part of a day to complete. Plus you will want an extra person to give you a hand. You don't need an extra person but it sure helps. The hardest part for me was removing the brake rotor from the hub and than also trimming the caliper to fit on the passenger side. I beat on the rotors forever and had no luck braking them loose. However, there are two empty screw holes that you can use to pop the rotors off. That required a trip to ace hardware to get the little metric screws needed. Other than those issues it was a relatively simple, follow the directions, type procedure. Use the spindle install guide here on the forums to guide you. And don't forget to set your toe-in roughly with a tape measure before you head to the alignment shop. i had mad toe-in after the install.
  13. Aug 11, 2010 at 8:36 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Sweet. Thanks for the heads up. I hear it's a beast. I'm worried about the brake lines too because I've never done that before.
  14. Aug 11, 2010 at 8:59 AM
    rzimm001
    Bobby
    Wildomar
    Oh heads up on changing the brake lines. When you remove the old lines, the nut/piece that you unscrew from the old lines, is mostly frozen in place and the hex is easily rounded off with a cresent wrench. Sometimes it comes off and sometimes you round it off the first try. If it comes down to it, I used two sets of vice grips in the most careful manner I could. When those nuts decide to be frozen in place they are very difficult to get out without destroying the nut. I think the metal is soft like aluminum or something. Best of luck to you on that.
  15. Aug 11, 2010 at 9:00 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    spindles= steering knuckles?
  16. Aug 11, 2010 at 9:02 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
  17. Aug 11, 2010 at 9:02 AM
    rzimm001
    Bobby
    Wildomar
    The verticle piece which connects to your upper control arm ball joint and your lower control arm ball joint. Holds the whole wheel hub assembly.
  18. Aug 11, 2010 at 9:03 AM
    rzimm001
    Bobby
    Wildomar
  19. Aug 11, 2010 at 9:07 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks! I can't wait to get these puppies on. They are beefier than I imagined?
  20. Aug 11, 2010 at 9:07 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    wow....
    http://www.popularmechanics.com/cars/how-to/maintenance/4213448
