Help with brake controller
Discussion in 'Towing' started by Ibffsteve, Sep 28, 2023.
  1. Sep 28, 2023 at 12:05 PM
    Ibffsteve
    Ibffsteve [OP] Member
    2015 Tacoma TRD Sport
    I have a 2015 Tacoma and I just installed a Prodigy P3 brake controller.
    The issue I'm having is the trailer brakes are not working when I push on the brake pedal, however they do work when I use the manual lever in the brake controller.
    Anyone have an idea where to start looking for the issue?
  2. Oct 2, 2023 at 5:31 AM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    Does your kit use the factory plug/harness or did you splice connections yourself?
  3. Oct 2, 2023 at 5:50 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'll start with the simple questions. When you press the brake, the screen on the brake controller should be showing a non-zero number (indicating the volts its sending to the trailer). With trailer connected and holding the brake pedal, what is that number? What is the number when you pull the manual lever all the way?
    AZ Pete likes this.
