Help with brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by loomitay, Aug 18, 2025.
  1. Aug 18, 2025 at 2:35 PM
    loomitay
    loomitay [OP] New Member
    Michael
    2006 4.0 L Tacoma Trd 4 x 4
    Hi
    I’ve been a mechanic for over 30 years, but with this one, I am stumped.
    My 2006 Toyota Tacoma 4.0 L 4 x 4 with 115,000 miles had a spongy pedal.
    The master cylinder and rear wheel cylinders were original equipment. I had changed the front brake calipers before but was over 10 years ago.
    Decided to replace everything, calipers, brake pads, brake lines, brake shoes, drums, rotors, wheel cylinders.
    I suction bled the brake system, but it was still spongy so I did a gravity bleed. Still spongy. I brought it to a friend of mine that has his own shop and he tried to bleed it, but said the master cylinder is bad or the ABS unit. There are no codes for the ABS unit, so I replaced the master cylinder with a higher quality aftermarket unit. I thoroughly bench bled and capped the ends to confirm pressure. Still has a spongy pedal.
    I took it to the Toyota dealership for diagnostic. they did a gravity bleed and tried to figure out what was wrong, but only came to the conclusion that the master cylinder should be replaced because it’s aftermarket unit.
    they confirmed all air has been removed from the system and that the ABS is functioning fine.
    Any ideas would be greatly appreciated. I had an old FJ 40 that had brake issues similar with a spongy pedal and I had to do a reverse bleed starting with the tire closest to the master cylinder get to get it to work.
    thanks
  2. Aug 18, 2025 at 2:39 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
    I dont know if this will help you out or not but I noticed a huge improvement in brake pedal firmness when I replaced front and rear brake lines with stainless braided lines.
    Tacorific likes this.
  3. Aug 18, 2025 at 2:43 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I have seen ABS units do this multiple times although not very often on Toyota.
    If you have a bi-directional scan tool you can command the valves in the ABS and see if any make a difference in the pedal.
    Toy_Runner likes this.
  4. Aug 18, 2025 at 3:01 PM
    loomitay
    Michael
    I do have access to the scan tool and I saw that information on Mitchell one software, but when I took it to the dealership, they said you do not have to do that for my 2006 model.
    they confirmed the ABS module is working fine and they had removed all air from the system
  5. Aug 18, 2025 at 3:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the rear brakes adjusted correctly? How's the parking brake? Does it set firmly?
    winkel and Jimmyh like this.
  6. Aug 18, 2025 at 3:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Rear adjustment is where I was going....
    winkel likes this.
  7. Aug 18, 2025 at 3:24 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    1) no chance the front calipers are on upside down/wrong sides?
    2) brake booster push rod length properly adjusted?
    Those are the 2 most common issues I've seen with brake issues. If those are good and no air in system, everything should work.
  8. Aug 18, 2025 at 3:31 PM
    loomitay
    Michael
    Rear brakes are adjusted correctly, and the parking brake is firm.
    front right & Left calipers are mounted correctly. Bleeder screw is at the top of the calipers
    pushrod lengths adjusted correctly, using the special tool provided- at zero clearance
    drizzoh likes this.
  9. Aug 18, 2025 at 3:40 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Hmmm and no vacuum issues with the booster and booster and master properly sized and lines hooked up correctly front and rear to the master? Any proportioning valve adjustment on there?
    I know you can make the ABS modules activate to force bubbles out on a per wheel basis, but it's a fairly involved process. A shops pressure bleeder should accomplish that same function as well though. That's a somewhat common issue on my gen of Supra, but more often than not its one of the other ones I've mentioned. Brake issues are frustrating as hell man, good luck.
  10. Aug 18, 2025 at 3:55 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    My money is on the ABS unit if the rear brakes are properly adjusted and there's no air in the system. I've seen quite a few Ford, GM, and a couple Toyota vehicles do that, sometimes you can go find some gravel and do a couple ABS stops and it will fix it if there's just some trash in one of the valves.
    winkel, blnewt, Jimmyh and 2 others like this.
  11. Aug 18, 2025 at 4:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If your truck uses the standard vacuum booster, you do have to purge the ABS pump.
    Unless you were super fast on the wheel cylinder change and know for SURE you got no air into the pump.
    I wouldn't take the dealerships word, since they probably don't know what they are talking about.
    There were some trucks that used the a different booster, but it was SUPER RARE on anything before 2009.
    I'd want to know for sure that they, dealership or who ever, DID do the ABS bleed procedure.
    Vacuum bleeding won't work......
    When I did my rear axle seal, I got air in the ABS pump.
    I had to go to a gravel parking lot and do the "slam on the brakes" bleed.
    Thankfully, the rear bleeder is easy to get to.
    And I had my brother to help.....(Hold the pedal down).
    I now have a scan tool........
    winkel, blnewt and loomitay[OP] like this.
  12. Aug 18, 2025 at 4:21 PM
    loomitay
    Michael
    Thank you for everyones help
    gonna recheck the rear brake adjustment after the shoes and drums break in a little bit more then try activating the ABS
    winkel likes this.
  13. Aug 18, 2025 at 4:25 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Watching…
  14. Aug 19, 2025 at 10:02 AM
    Moto521
    Moto521 Well-Known Member
    2006 Tacoma DCSB TRD OR
    Can you pump up the pedal with the engine off and get a firm pedal?
    I just went through this with mine. When I bought it the pedal had excessive travel and the e brake was low.
    Replaced the worn out shoes and replace the drums/wheel cylinders with oem. Was much better but still didn't "feel" right .Didn't stop the way I thought it should. Bled the crap out of it. Pedal and e brake felt okay, but still didn't feel 100%.
    Anyway, just kept driving it and gradually I think it took quite a while for the shoes to bed into the drums and eventually it felt pretty good. Have since replaced the original rotors(19 years old)and pads(with oem) and now it feels like it should.
    *Retired auto tech with over thirty years of experience
  15. Aug 20, 2025 at 7:21 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I hated the brake pedal feel on my 2008 X-Runner since the day I drove it off the lot (in 2008). I even took it back to the dealership, and the technician said it's the way they normally feel. I've owned several different vehicles, from previous Toyotas, BMWs, Acuras, Porsche, Chevrolet, etc. and none had that "stepping on a mushroom" feel like my Tacoma.
    I eventually got rid of it a few years ago when I installed a BBK and SS brake lines.
    BluberryBCtaco likes this.
  16. Aug 20, 2025 at 2:36 PM
    blnewt
    blnewt Well-Known Member
    Brad
    2015 Gray metallic Double Cab V6 4x4 SR5
    Sounds just like my 2019 Jeep Wrangler. Like previous replies, a few runs down a gravel road w/ several slams of the brake pedal were enough to get the air to purge from the ABS system. I would bet the farm that that's what's going on here.
    winkel likes this.
