Help with breather locations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LiveFreeOrDie2015, Sep 11, 2015.
  1. Sep 11, 2015 at 8:35 PM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 [OP] Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I know I've seen a thread with 5-6 breather locations but Google and TW search failed me.
    I found the 3 in engine bay and the rear diff but where are the other ones for a 2015 DCSBOR please post links or pics on the 1-2 that im missing. Thanks
  2. Sep 12, 2015 at 4:55 AM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
  3. Sep 12, 2015 at 4:29 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
  4. Sep 12, 2015 at 4:33 PM
    Pigpen
    Dan
    Northwest Montana
    Engine bay has the front diff and t case breather IIRC, and the rear diff is easy enough - as you stated.
    I think the trans breather comes up to the cab by the shifter.
    Not sure what else would need to breathe. Maybe I'm having a senior moment...
  5. Sep 12, 2015 at 4:39 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    When I installed my 120v outlets in console I don't remember seeing anything there ( had the whole thing removed) the engine bay has two beside fuse box and one on passenger side at emissions pump.
    So you think I'm only missing the rear diff?
  6. Sep 12, 2015 at 5:11 PM
    Pigpen
    Dan
    Northwest Montana
    Yep. I think you just need to do the rear diff relocation. I put mine in the tail light. It takes a bit more hose, but I like it better than the gas cap area.
  7. Sep 12, 2015 at 5:13 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I was planning on making them all two way breathers with a filter instead of spring valve .......any thoughts on that?
  8. Sep 12, 2015 at 5:24 PM
    Pigpen
    Dan
    Northwest Montana
    I thought the spring valve was only on the rear diff - but I'm by no means certain about that. I thought the replacement breather was a true breather (two way).
  9. Sep 12, 2015 at 5:30 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    They all looked the same to me the new one just has a barb fitting instead of threads but you could be right. That's way im asking for help before I buy everything. Hope to do mod next weekend
  10. Sep 12, 2015 at 5:33 PM
    Pigpen
    Dan
    Northwest Montana
    If you're thinking about using filters, there's not really a reason to use the breathers. Just a thought....just terminate with the filters.
  11. Sep 12, 2015 at 5:38 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I wasn't planning to but need to order barb adpt in rear diff for tubing. Just wanted to know if I needed 2-3 of them
  12. Sep 12, 2015 at 5:57 PM
    Pigpen
    Dan
    Northwest Montana
    one barbed and threaded adapter, one barbed breather
  13. Sep 12, 2015 at 5:58 PM
    Pigpen
    Dan
    Northwest Montana
    The rear diff breather mod for dummies should have part numbers, if you need them. Perhaps info on breather type too.
  14. Sep 12, 2015 at 6:00 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Thanks for your help
  15. Sep 12, 2015 at 6:11 PM
    Pigpen
    Dan
    Northwest Montana
