Help with broken antenna installation
Discussion in '1st Gen. Tacomas (1995-2004)' started by ufsurfer, Jan 19, 2010.
  1. Jan 19, 2010 at 9:26 AM
    ufsurfer
    ufsurfer [OP] New Member
    David
    Daytona Beach
    sr5
    The pros want to charge me $75-100 to replace a broken antenna. Don't have that to spend. Anyone have some tips for getting access to the radio antenna outlet? What needs to be unscrewed etc.....I can deal with the wheel well covering..but don't know where to go after that.
    Thanks, David
  2. Jun 1, 2010 at 5:10 PM
    Berlin
    Berlin Member
    Houston, TX
    Prerunner TRD Sport
    Bump.
  3. Jun 1, 2010 at 5:16 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    well, if you actually need to remove the old antenna wiring, you pretty much have to pull the whole dash off as there's some clips holding it in place along the main support.
    If you dont care about leaving the old one in place, you could just pull the radio ( http://www.customtacos.com/tech/index.php?article=77 - stop at step 5) and the molding under the glove box and run a whole new wire. I believe there is also a plastic protector in the wheel well that will have to be removed to get access to the antenna.
    Personally, probably worth the $75-100 to get it done if you're talking about replacing the whole wire and everything, unless you have a few hours to tinker around with it.
    Now, if you just need to replace the antenna, I believe that can be done a lot easier by just removing the plastic shielding in the wheel well and undoing a few screws.
  4. Apr 21, 2014 at 12:15 PM
    bbk3e
    bbk3e Member
    Raleigh
    99 Tacoma
    mostly stock
    This is an old thread, but I just had to replace mine, so I'm posting how I did it:
    1) I purchased a set of screw extractors - http://www.amazon.com/gp/product/B000GTOOWA/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
    2) I used a 1/8" drill bit and a hammer drill to drill into the stub that was still in the antenna mount.
    3) I used the smallest screw extractor bit, but it didn't bite, so I went to the next size up and slowly worked the broken piece out.
    4) I will replace the antenna mast with either OEM or after-market.
    The extraction process (steps 2 and 3) took less than 5 minutes.
  5. Apr 21, 2014 at 2:49 PM
    WThomas1250
    WThomas1250 Well-Known Member
    I need to do this soon. Thanks for posting!!
