HELP WITH BUDBUILT SKIDS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aw10tacoma, Jun 22, 2015.
  1. Jun 22, 2015 at 10:50 AM
    aw10tacoma
    aw10tacoma [OP] backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    Hey guys I recently bought the full skids from a buddy and he's got a 12 off-road double cab my truck is 11 base access cab I called bud and they said the parts were compatible. Now I tried installing the front and nothing lines up. The gas skid doesn't even have anything on the tank to bolt onto... I'm completely lost and usually have no problem installing stuff but I give up any chance anyone could give me any ideas of what I'm doing wrong. I also go new hardware from bud to install.
    Thanks
  2. Jun 22, 2015 at 3:34 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Have to do the front one first. I think the ones after the IFS skid mount to each other
  3. Jun 22, 2015 at 3:46 PM
    Pigpen
    Dan
    Northwest Montana
    And you need to get gas tank hangers for an Off Road to mount a tank skid
