Help with build - icon stage lift and 285s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skyking90, Nov 4, 2016.
  1. Nov 4, 2016 at 7:12 PM
    Skyking90
    Skyking90 [OP] Well-Known Member
    Steven
    Anchorage, Alaska
    2016 Tacoma TRD Sport
    Icon Stage 4, STT Pro 285/75/16, SCS Stealth6, Bakflip MX4
    looking at some of the icon suspension lifts for my 16' tacoma 4x4 dbl cab sport. I would like to put on 285/75/16s. Anyone have any opinions on what has worked for them. I am okay with minor cutting but wont be doing a whole lot of intense off roading. Just a lot of dirt/gravel roads and of course street roads.
    Been looking trough the forums for quite some time now and am having a hard time on choosing the right kit, tire/wheel size and any other accessories I may need on top of one of the icon stage kits.
    I know there is a search function, trust me i've used it. If anyone has pictures of their setup with what I am talking about, I would love to see them.
    Thanks guys
  2. Nov 4, 2016 at 7:20 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Do this and not worry:
    265/70R17
    I went with 5100s and 885s with Icon rear progressive AALs from Headstrong....
    You will absolutely go happy... different truck beefier ride with no lean and in 4x4 hit the gas.... street great trail great. The Sport suspension is harsh in comparo.
    dYL0n likes this.
  3. Nov 4, 2016 at 8:19 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    You're not searching right
    backcountryj and Midnighttaco08 like this.
  4. Nov 6, 2016 at 2:18 PM
    Skyking90
    Steven
    Anchorage, Alaska
    Planning on installing icon stage 4 lift (tubular) with cooper stt pro 285 75 16s.
    I would like to use scs wheels. Anyone else with this combo? Scs seems to be sold out of the matte jet black on some wheel options though... i like method but dont like the fake beadlock pattern in chorme or gold. Anyway to change it to black?
  5. Nov 6, 2016 at 2:21 PM
    Skyking90
    Steven
    Anchorage, Alaska
    Also is there going to be a huge difference between stage 4,5 or 6 icon lifts? From the parts list looks like the reservoir goes from a 2.0 to a 2.5 and the stage 6 offers adjustability depending on what type of ride you want for a given time. Worth the extra $$?
  6. Nov 6, 2016 at 2:27 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    you're gonna have to max out the lift, do a cab mount chop, beat the shit out of the pinch weld, trim the flares, and need a lot of positive caster. You'll probably still rub the front bumper cover some at full lock going over bumps unless you get a plate bumper. Icon lists prices on their website
    dYL0n likes this.
  7. Nov 6, 2016 at 2:42 PM
    Skyking90
    Steven
    Anchorage, Alaska
    Seems like some have issues with rubbing, some dont on the 285's. Hard to say really. What size down from a 285/75/16 would work better? I really like the 285 look.
  8. Nov 6, 2016 at 2:53 PM
    gottaToy
    JJ
    1985 Moped
    they're full of shit if they run 285's and NOT rub. Even with a 265/75/16, you'll rub a little without positive caster, but won't need to trim much. If buying new wheels, save yourself some trouble and get 17", the 16" are really close to the caliper and some idiots will put the wheel weights where they will hit and get knocked off, or they make the fronts clear, then you go and rotate tires and knock them off the tires that were on the rear. Not so much with 265's, but the 285's are a bitch to get balanced and might need a lot of weights. You might be able to find a 255 tire that will is close to the overall diameter of a 285? Some say those will work without much rub because they are skinnier than a 285, but close in diameter.
    TacoRD16 likes this.
  9. Nov 6, 2016 at 5:20 PM
    Skyking90
    Steven
    Anchorage, Alaska
    Okay so if it's not a 285/75/16 then what 275 would work better? I really wouldnt like to drop to a 265...
  10. Nov 6, 2016 at 5:55 PM
    tazmkny
    tazmkny Member
    ^^ Hit it on the head. I just did a stage 7 ICON kit and had to chop and trim the fender liners and flares in order to get it to not rub moving forward. In reverse from mid to full lockout i still get a little bodymount and air dam rubbing. The rear has never been a problem the front depending on the offset of the wheel will get the common spots that are mentioned routinely on the forum. This is my 3rd lifted Tacoma and I've had a 4runner as well with comparable suspension and once you dial in the common accommodations of trim and cutting its no worries. For many people they cringe at the sound of cutting things which makes the worry warts stop from moving forward with any mods. Honest option of course.
  11. Nov 6, 2016 at 6:06 PM
    BCJake
    BCJake Well-Known Member
    BC
    2016 Tacoma TRD OR AC MT QS
    -5100's all four corners, fronts set at 0 -888 OME coils, SPC UCA's, Deaver AAL -Driver's sidefront spacer -SCS 16" Ray10's in Matte Dark Bronze -255/85/16 Toyo MT's -Avid Off-Road weld on sliders -RCI Front Skid -SSO Slimline Hybrid front bumper, Smittybilt X20 Winch -Flipster V2 front plate bracket -FabFours Premium rear bumper -Front diff needle bearing delete, ECGS bushing in -Plasti dipped front grille -G-Tek Fab door sill guards -CaliRaised 2X2 Ditch Lights -ARB CKMA12 Compressor & Slee OffRoad Mounting Bracket -Shapeways 2 Switch Plate
    After doing some research, I'm starting to lean towards 255/85/16. Was originally not entertaining the idea of the skinny tire but with the proper aggressive tread, this might just be the direction I will head. Minimal if any trimming required on a 3' lift. Fills up the well nicely on a lifted truck and will work just fine for my application.
  12. Nov 6, 2016 at 6:18 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I would stray from the 255 since 285's look to skinny already. Get 285's with 4.5 back spacing wheels and prepare to cut and do body mount chop if you do any form of off roading.
  13. Nov 6, 2016 at 6:19 PM
    TacoRD16
    Houston, TX
    Amen
    dYL0n likes this.
  14. Nov 6, 2016 at 7:02 PM
    BCJake
    BC
    I don't know about that. LadyRed has some Toyo Open Country 255/85/16 M/T's on her 16 and they look just fine to me. I'm also trying to balance purpose with appearance. With this truck already having some gearing issues, last thing I want to do is run 285's. Besides, it's all a matter of perspective. You're always going to find someone running ridiculous tires that will make yours feel inadequate.
  15. Nov 6, 2016 at 8:40 PM
    Skyking90
    Steven
    Anchorage, Alaska
    What 4.5 backspacing wheels you guys recommend? I like scs a lot but seems they are sold out in the dark colors. Method is alright but i dislike that fake beadlock look. What else would be a solid option?
    I think I will go with the 285/75/16... i know if i go 275 or 265 i will regret it later on and want the 285s.
  16. Nov 6, 2016 at 8:42 PM
    Skyking90
    Steven
    Anchorage, Alaska
    Also did you do any sort of regearing? Seems like some do it others don't. Guess its best to see how it runs after amd go from there.
  17. Nov 6, 2016 at 11:38 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    This.
    :deadhorse:
    dYL0n[QUOTED] likes this.
  18. Nov 7, 2016 at 8:02 AM
    TacoRD16
    Houston, TX
    I know its more of a personnel preference but I would really advise you to see those tires in person. 285's are only ~11.2" wide when I think 33x12.5" are the standard look. Plus you are going to pay a little more for a 255/85 since its not really a standard size and will have to be ordered. If you are looking at E rated tires you are only looking at around 5 lb diff which is a total of 20 lb rotating mass which is around 60 lbs static load which isnt that much to really affect the feel of gearing. I'm all for purpose thats why I paired my KO2's 59 lbs with 16" FN wheels 18 lbs a wheel with the correct 4.5" back spacing. Stock wheels are ~24 lbs and most aftermarket ranges from 24-29 lbs a wheel alone.
    Just looking out for you from buyer regret.
  19. Nov 7, 2016 at 8:04 AM
    TacoRD16
    Houston, TX
    I went with FN konig Countersteer wheels 16" @ 18 lbs a piece with 4.5 BS. Even with this set up I was thinking I need 35" tires instead.
  20. Nov 7, 2016 at 8:10 AM
    TacoRD16
    Houston, TX
    At 33" tires its hard to justify regearing cost. I will tell you once you install tires disconnect the battery to force the computer to relearn driving habits. It will eventually learn with out disconnecting the battery but it will still think you are on stock tires and the shit points aren't the same with larger wheels just so slightly. This will help a little. Once these tires go then I plan on going to 35" than I'll regear to 4.88 but this will all begin once the truck is paid off.
