Help with cable modem log messages
Discussion in 'Technology' started by JEP, Nov 27, 2011.
  1. Nov 27, 2011 at 1:20 PM
    JEP
    JEP [OP] Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    Any one what these log messages mean and what I can do st stop them? I keep losing my internet connection and the cable company and Motorola have been of no assistance. First screen is the log the second is the power levels which are about in this range every time I check them. any input would be greatly appreciated.
  2. Nov 27, 2011 at 5:50 PM
    JEP
    Madison
    15 DBL V6 4WD
    Bump
  3. Nov 27, 2011 at 6:03 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Seems to me to be an issue with the cable modems ability to sync. It is not getting a response to it's dhcp request. This is a cable company issue. They need to test the signal. This could be a loose connection or a bad cable end somewhere in between your cable modem, and the cable companies equipment.
    Good Luck.
  4. Nov 27, 2011 at 6:06 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    x2
  5. Nov 27, 2011 at 6:22 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    DHCP is your modem trying to establish an IP address from your ISP and is failing,
    Is the modem registered with your ISP? You will need the Mac address.
  6. Nov 27, 2011 at 6:22 PM
    JEP
    Madison
    15 DBL V6 4WD
    Thanks guys. I will have to get after Charter some more, they are giving me a hard time because I own the modem and do not rent it from them for $5.00 a month
  7. Nov 27, 2011 at 6:23 PM
    brian
    Elizabeth City, NC
    And idk but that downstream power seems off
  8. Nov 27, 2011 at 6:24 PM
    brian
    Elizabeth City, NC
    If you didn't provide the Mac address to them when you signed up...then its likely your issue
  9. Nov 27, 2011 at 6:25 PM
    JEP
    Madison
    15 DBL V6 4WD
    Yes it is registered with them, it was working for 10 months then suddenly I have this issue.
  10. Nov 27, 2011 at 6:51 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Charter should be able to do a diagnostic from their end.
    If they ask just tell them that the modem is from them,,,,you bought it from them, right ? (then they should support it)
    If you have some aftermarket modem not from Charter, then you are tech support ;) (The tech's cheat sheet will be for a specific make/model of modem.)
    Don't get into modem ownership with the tech if you don't have to.
    One of the first things that the tech may have yo do is a "power cycle".
    That's is simply pulling the power off the modem for a minute or two and then re-plugging it in. This forces a reset and is often the fix.
    If you haven't tried a power cycle, do it now.
    If that doesn't work, grab your set up guide that came with the modem and go through the set up again.
