Help with correct LCA OEM bushing number!
Discussion in 'Suspension' started by wmflyfisher, Aug 4, 2013.
  1. Aug 4, 2013 at 6:42 AM
    wmflyfisher
    wmflyfisher [OP] Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    Ok, I ordered a LCA bushing from toyota but it was too long. Below is what I came up with. I need the lower right side FRONT. Which of these below is the right front lower bushing?? No.1 or No.2?? Any assistance would be great.
    Toyota part # 2007 Tacoma 4wd/Prerunner:
    48654-04040 BUSH, FRONT LOWER ARM, NO.1 LH
    48654-04040 BUSH, FRONT LOWER ARM, NO.1 RH
    48655-04020 BUSH, FRONT LOWER ARM, NO.2 LH
    48655-04020 BUSH, FRONT LOWER ARM, NO.2 RH
    48632-04020 BUSH, FRONT SUSPENSION UPPER ARM, LH
    48632-04020 BUSH, FRONT SUSPENSION UPPER ARM, RH
  2. Aug 4, 2013 at 6:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This was my parts list when I changed out my bushings (bushing part numbers in red):
    4865504020 BUSH, LWR ARM, NO.2 2 EA
    4865404040 BUSH, LWR ARM 2EA
    4819860011 CAM, CAMBER ADJUST 2 EA
    4819060020 CAM ASSY, CAMBER ADJ 2 EA
    90178A0013 NUT, FLANGE 4EA
    4840960020 2EA
    4845235030 2 EA
    90119-A0166 2 EA
    I'm not sure how to tell which one is the front and rear but they are the same side to side for a given location (the fronts are the same and the rears are the same but the fronts are different than the rear).
  3. Aug 4, 2013 at 7:13 AM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Thanks Pug.
  4. Aug 5, 2013 at 7:50 AM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Anybody else know??
  5. Aug 5, 2013 at 7:53 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Which one did you order first? Order the other one.
  6. Oct 12, 2013 at 8:57 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    JUST A FYI 48655-04020 IS REAR BUSHINGS
