Help with dash lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Norcalkid, Dec 28, 2010.
  1. Dec 28, 2010 at 4:36 PM
    Norcalkid
    Norcalkid [OP] Well-Known Member
    Jeff
    Willows ca
    99 prerunner sr5
    Icon coilovers, rear icon gas shocks with resevuar. 100 serries American eagle wheels wrapped in 33 in bfg ta's
    Took my truck offroading and when it got dark I switched my lights on and my dash lights didn't come on. Checked all the fuses and shut but all was well. Any advise short of tracing wires?
  2. Dec 28, 2010 at 4:51 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    did you twish the knob on your dash next to the steering wheel?
  3. Dec 28, 2010 at 5:23 PM
    SonnysTile
    SonnysTile Well-Known Member
    Sonny
    Louisville KY
    '04 TRD Dbl Cab 4x4 Limited
    A shitty snugtop, step bars, wheels, and vent shades... For now.
  4. Dec 28, 2010 at 11:15 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    if its all the lights you probably have turned the dimming knob down. if not, search for a thread on how to remove your stereo, pretty simple but some need the photo/direction assistance. if will also show how to remove your dash across from the stereo trim to the gauge cluster. i believe there are 4 illuminating bulbs, which i found could only be had from toyota for about 8 dollars each. i had one bulb go out in my tach and had to tare the whole dash apart to change. not too bad, but will take some time and patience. id bet, like others have said, its the illumination knob just turned down.
  5. Dec 29, 2010 at 9:13 AM
    Norcalkid
    Jeff
    Willows ca
    99 prerunner sr5
    That was my first thought but the knob didn't do anything and all my fuses are good. I doubt all the bulbs would go out at the exact same time. It's all the dash and the lights behind the heater and A/C. And I put a new stereo in once I bought the truck about a year ago. Lookin like I gotta trace wires... Maybe one popped loose somewhere or something.
  6. Dec 29, 2010 at 3:06 PM
    Norcalkid
    Jeff
    Willows ca
    99 prerunner sr5
    maybe the dimmer switch?
  7. Dec 29, 2010 at 10:49 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Or it got unplugged behind the dash.
  8. Dec 30, 2010 at 11:04 PM
    Norcalkid
    Jeff
    Willows ca
    99 prerunner sr5
    Yea that would make sense, as hard as I was beatin on it hahaha
