Help with dead ecu’s after tune - issue located
Discussion in '4Runners' started by NorthPark, Aug 4, 2023.
  1. Aug 4, 2023 at 2:13 PM
    NorthPark
    NorthPark [OP] Well-Known Member
    Update: issue isolated, putting it all back together right now. I’ll provide more details when I’m in front of a keyboard
    1gr-fe 4.0 2018 4runner w/ procharger hptuners rtd
    My 4runner seems to be eating ecu's.
    I installed a pc kit and was able to start it afterwards. It ran a few times then suddenly died and I could not pull any codes from the ecu..
    Then last week I installed a replacement ecu and tech stream could see it. I coded the immobilizer with the 4/13 pin jump and set the vin on the ecu. It started up and ran a few times so I figured I was safe and applied the tune.
    A couple starts after this tune, the replacement ecu was dead and no longer responding to tech stream or any of my code readers.
    Is there some sort of security function that's killing my ecu's? I have a third ecu I'm going to install this weekend and will try to start it a few more times before attempting anything else...
  2. Aug 4, 2023 at 2:17 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Don’t tune the 3rd one lol….
    xtremewlr, TS4x4 and bkhlrTaco's like this.
  3. Aug 4, 2023 at 2:36 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I'm no programmer and know little to nothing about tunes but it sounds like your tune files are corrupted.
    TS4x4 likes this.
  4. Aug 13, 2023 at 6:34 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Is this a brand tune or a custom tune. If brand, which one?
  5. Aug 13, 2023 at 6:38 AM
    tcjacado
    tcjacado Well-Known Member
  6. Aug 13, 2023 at 9:47 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    He has a procharger and using HPtuners software.
    Maybe @mZiggy can help? Or Someone who uses the HPtuner software.
    mZiggy and tcjacado[QUOTED] like this.
  7. Aug 13, 2023 at 11:19 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I wonder if your tune has a table with a severely incorrect table axis values(s) that is bricking it whenever that scenario is encountered upon driving.
    To me the order of events described, including the truck reportedly being fine pre-tune, points to the tune being the issue in some way
  8. Aug 24, 2023 at 4:42 PM
    NorthPark
    It does not seem to be an ECU issue at this point, but I can't seem to track it down. I've gone as far as probing and scoping the bus system and don't see anything out of line. I have no electrical modifications right now, everything has been completely disconnected.
    I'm following the TIS step by step for U0100 and CAN issues and it keeps pointing me to replace the ECU, however I have 4 ecu's now. All of them can communicate with tech stream on a bench top setup. I see healthy CANh/l on the scope ( I think? ) and power at the ecu port.
    Originally it was making an odd buzzing sound in the passenger engine bay, which stopped when I disconnected the power steering pump. Tech stream at the moment can communicate with the power steering though.
    Is this something where a sensor might be shorting out something when the ECU is plugged in?
  9. Aug 24, 2023 at 4:44 PM
    SmoothTRD
    SmoothTRD Well-Known Member
    Do you have good internet service?
  10. Aug 24, 2023 at 4:45 PM
    NorthPark
    It’s not great in the garage but I can tether a laptop in there.
  11. Aug 24, 2023 at 4:48 PM
    NorthPark
  12. Aug 24, 2023 at 4:48 PM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Are you using hacked techstream? Potential malware?
    Canadian Caber likes this.
  13. Aug 24, 2023 at 4:49 PM
    NorthPark
    Cracked yes but I have 2 ecu’s untouched which do not work in the vehicle, all 4 ecu’s communicate on the bench. Techstream is installed in a vm.
    TS didn't come into play until after the first failure
  14. Aug 24, 2023 at 6:07 PM
    SmoothTRD
    Use better internet service to avoid any other issues
  15. Aug 24, 2023 at 7:17 PM
    NorthPark
    Just found that if I leave B36 disconnected from the ECU that suddenly everything starts working.
    Since I sorted out the ECU pins for the bench top it had me realize that the ECU only needs F51 (power) F50 (CAN) and B38 (ground) for it to start communicating, I only plugged those in and was able to see the ECU, then from there just started plugging in the rest one by one until it failed.
    I traced and scoped every connection in the TIS guide for ECU communication issues and everything checked out. Everything in the guide just points an ECU replacement, but that doesn't seem to be the case for my problems.
    Looks like B36 is
    Camshaft timing oil control valve (for exhaust side of bank 2)
    Heated oxygen sensor (4 pins)
    Power source for VVT sensor (4 pins)
    VVT sensor (Banks 1&2)
    Crankshaft position sensor
    Air switching valve for secondary air injection system
    Power source for canister pressure sensor
  16. Aug 25, 2023 at 7:49 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Have you contacted HPTuners at all to see if they can give you any help? I think at this point, now that you kind of have the issue pinpointed to the B36 connector, you need to start talking to someone that knows the inner workings of the ECU a little better. B36 is kind of a big deal if it controls what you say it does, as those are all critical engine controls.
    I was going to suggest verifying the wiring harness but since you are replicating the issue by bench testing the ECUs, that rules out the wiring being a problem. Neither of the ECUs pictured have tunes applied to them yet?
  17. Aug 25, 2023 at 9:32 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    What?
  18. Aug 25, 2023 at 11:14 AM
    NorthPark
    Seems like something in B36 is shorting out the ecu when connected, I don't think it has anything to do with the tune.
    It just hid its self as an ecu issue, and following the tis for ecu no start/no communication sent me down a different path.
    I have the spec's for the pins there but will have to wait until tomorrow morning until I can really start sorting it out.
  19. Aug 26, 2023 at 12:45 PM
    NorthPark
    The 5v is messed up on this circuit
    (4.5-5.5v spec)
    B36-15 B38-12 VVT sensor 0v
    B36-16 B38-12 VVT sensor 0.76v
    B36-15 B37-8 Power source for cannister 0.13v
    B36-26 B38-12 Air Switching Valve 12.6v (Bat)
    B38-12 is ground
  20. Aug 26, 2023 at 2:13 PM
    NorthPark
    Not out of the woods yet, but I found that the intercooler plumbing was crushing the Bank 1 VVT sensor connector. I adjusted everything and now I can see the factory ECU. Putting it all back together now.
    The fitment of this PC kit is very tight in the engine bay, my biggest concerns after installing the kit is how much I reduced the offroad reliability. Once I get this up and running I'm going to have to go back and check the fitment of the entire system.
    It's a nice hot 107f day to put this all back together.
    1Manoperation and xtremewlr like this.
