Help with Diag. 2015 DCSB
Discussion in 'Technical Chat' started by corharps, Jun 13, 2025.
  1. Jun 13, 2025 at 9:17 AM
    corharps
    corharps [OP] Member
    I’m hoping someone can help me with some diagnostics. I have a Bilstein 6112 lift on my truck, 120k miles. I have noticed a progressively worsening symptom. I just took it to a shop and they couldn’t find anything wrong.
    timeline of the issue:
    1. Noticed vibration only at 40mph
    2. Noticed a clanging when accelerating at low speeds that would go away after passing a certain speed
    3. Present: notice both a vibration/shake up through 50mph accompanied by a squeak/bird chirp sound. If I stop accelerating at any speed along the way both vibration and sound go away. They restart immediately when hitting the accelerator again. If I hit cruising speed or drive for a while I notice both things go away completely, until I come to a stop again and it restarts.
    the shop only rotated my tires. They didn’t have really any other clue. Had them check the idler pulley and they didn’t think there was any issues.
  2. Jun 13, 2025 at 9:21 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Chirp/squeak makes me thing u-joint(s). Does the frequency of the noise change as you go faster or slower?
    MR5X5 likes this.
  3. Jun 13, 2025 at 12:29 PM
    corharps
    After about 20 mph it starts, it gets worse as I accelerate until about 60. But if at any point I let off the gas it stops completely. So it doesn’t rumble or chirp if I’m coasting
  4. Jun 13, 2025 at 12:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    If that’s the original belt, I’d change that old thing.
    corharps[OP] likes this.
  5. Jun 13, 2025 at 1:00 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    If the noise is there & you can replicate it, find a real shop that has a clue & does real automotive repair type stuff....
    Could still be u joints regardless that it doesnt do it while coasting...
    Could be anything, a tech need to isolate & pinpoint the noise.
    Figure out where its coming from & not just dice rolling.
  6. Jun 14, 2025 at 8:43 PM
    corharps
    Well was hoping someone would know but I know that’s hard without hearing it. Little update, the chirp almost entirely goes away the more I drive the truck. I don’t drive it a lot in general. However the shake/vibration happens from 20mph and up. And seriously, when I step of the accelerator it immediately stops, and immediately restarts when I hit the gas. Kind of reminds me of my busted motor mounts on my old jeep. Could it be that?
  7. Jun 15, 2025 at 5:22 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I'm thinking U-joints also.
    Grab ahold of the rear driveshaft next to each U-joint and yank back & forth on it looking for any play in the joints (be sure there's no tension on the shaft though... Have the truck in neutral, brake applied and the wheels chocked... Alternatively, you can also jack the rear wheels up off the ground).
    You're looking for any movement besides rotation... So up/down, in/out, etc. Also any clunking that is not related to rotating it. There should be none.
    (a little movement in the rubber around the center carrier bearing is OK, but if it's very loose or sloppy, then that could be your issue too).
    SR-71A likes this.
  8. Jun 16, 2025 at 12:01 PM
    corharps
    Thanks everyone, I am going back to the shop. They are looking into U joints and axles. I will get back to everyone with an update
  9. Jun 17, 2025 at 5:16 PM
    corharps
    U joints and center bearing. Thanks fam!
  10. Jun 18, 2025 at 8:31 AM
    MR5X5
    MR5X5 Well-Known Member
    Personally I'd start with the u-joints before convincing myself the carrier is bad too.
  11. Jun 18, 2025 at 8:39 AM
    SR-71A
    Zack
    Southern Maine
    While the driveshaft is out and with 120k miles on it.. Id say its smart to do them all at the same time.
  12. Jun 18, 2025 at 1:26 PM
    MR5X5
    Perhaps, but the carrier is significantly less fun to do than the u-joints. If I were turning my own wrenches I'd do them incrementally. FWIW I don't consider 120k miles to be particularly significant.
