Help with drums
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Adventuretaco13, Feb 23, 2023.
  1. Feb 23, 2023 at 7:32 AM
    Adventuretaco13
    Adventuretaco13 [OP] Well-Known Member
    Downingtown, pa
    2020 Tacoma TRD sport
    So I go to move my truck and it won't budge. I mistakenly washed my truck yesterday. I knew the drums were frozen, I've managed to get the PS rear wheel moves but the DS is locked. Things I've tried:
    Beating on the drum
    Tapping on the back side
    4Hi
    4lo
    Space heater
    Praying and cursing
    Should I just wait for the weather to warm up above 32 degrees or what?
  2. Feb 23, 2023 at 7:36 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Take the wheel off and get 2 M8 bolts and there is 2 threaded spots on the drum. Run 2 bolts in a little each time and it will pop that drum off the pads!
    Vlady, asuchemist and MSN88longbed like this.
  3. Feb 23, 2023 at 7:39 AM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    The one time I had this happen I just accelerated through it 5 feet, and they released like normal.
  4. Feb 23, 2023 at 7:51 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Take the wheel off and really heat the drum. Its a lot of iron will take time to warm up. Dont need it scorching hot just warm.
    Also check the cable isnt frozen if you use the parking brake
    AllTacosFloat and wilcam47 like this.
  5. Feb 23, 2023 at 7:57 AM
    BJamesBeck
    BJamesBeck Well-Known Member
    Illinois
    2016 TRD OR Magnetic Gray Metallic
    When I did the drums on my 2nd Gen, the M8 bolts worked like a dream!
  6. Feb 23, 2023 at 8:01 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    That sucks.
    I don’t understand why some have issues with the drum brakes after washing their truck in freezing temps.
    I rinse my truck pretty much everytime I drive on salty roads and never once had my drums seize up.
    My drums never been opened/adjusted either, I should do it when weather warms up.
    shakerhood likes this.
  7. Feb 23, 2023 at 8:03 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I would apply some direct heat to the drums where the shoes rest; a propane torch is ideal. You don't need to get things red hot, just get the metal good and hot to the touch. if that doesn't do it, you have bigger problems. The bolt method will work, but if the shoes are 'rust-welded' to the drums, you could damage stuff by forcing it.
    RustyGreen, SR-71A and wilcam47 like this.
  8. Feb 23, 2023 at 8:04 AM
    Adventuretaco13
    Downingtown, pa
    Thank you guys for your help. I'm going to try the M8 bolt trick.
    moe2o4 likes this.
  9. Feb 23, 2023 at 8:06 AM
    Adventuretaco13
    Downingtown, pa
    I only have 16000 miles on the truck. I really hope it's just the cold. But why would one side release and not the other?
  10. Feb 23, 2023 at 8:19 AM
    Adventuretaco13
    Downingtown, pa
    Could the brake actuator be the issue?
  11. Feb 23, 2023 at 8:22 AM
    lbhsbz
    lbhsbz Well-Known Member
    No, it'll tear the shoes off the backing plate destroying the hardware in the process.
    Those holes are to break the drum free from hub when rust has stuck them together.
    don't do this.
    If the heater got the drum above 32 degrees for any sort of period of time, we can assume it's not frozen (temperature).
    2nd and 3rd gen have a screwy parking brake actuator mechanism that likes to hang up sometimes when it goes over center...which is shouldn't with only 16K miles worth of wear. I had my 2nd gen get stuck on a boat launch ramp and it was a pain in the ass, being by myself and it being a manual trans.
    Keep doing what you're doing, eventually it'll work.
    SR-71A and Chew like this.
  12. Feb 23, 2023 at 8:27 AM
    BJamesBeck
    Illinois
    Did you try setting a releasing the parking brake? That could possibly be what froze.
  13. Feb 23, 2023 at 8:47 AM
    Adventuretaco13
    Downingtown, pa
    Anyway it could be my e brake..
  14. Feb 23, 2023 at 8:50 AM
    BJamesBeck
    Illinois
    Just a thought, I know it's basically just a cable that goes back to the drum, or was on the 2nd Gen anyway. I haven't pulled apart the drums on my 3rd Gen yet.
  15. Feb 23, 2023 at 8:54 AM
    SR-71A
    Zack
    Southern Maine
    Do you normally use your parking brake?
  16. Feb 23, 2023 at 9:04 AM
    Adventuretaco13
    Downingtown, pa
    Yes but I never washed it then it dip below freezing last night. It's currently just 30 degrees here. When I get back I'll pull on the e brake cable, try a heat gun, and if I have to I'll use the M8 bolt method.
    BJamesBeck likes this.
  17. Feb 23, 2023 at 9:07 AM
    BJamesBeck
    Illinois
    Just as a side note, when I pulled off the drum with the bolts it didn't damage any of the brake hardware inside, but that may be different for you depending on the ice situation/if there is ice built up inside of it.
  18. Feb 23, 2023 at 9:25 AM
    lbhsbz
    If the drum turns and the shoes aren't stuck to it, it will come off. If the drum is stuck to the shoes for whatever reason...you'll be buying hardware.
  19. Feb 23, 2023 at 9:30 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    How'd you get the passenger side freed up?
  20. Feb 23, 2023 at 9:32 AM
    Adventuretaco13
    Downingtown, pa
    I banged on the drum and 4lo..
