Help with electrical connection on "accessory" circuit.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GrizzledBastard, Nov 20, 2021.
  1. Nov 20, 2021 at 1:08 PM
    GrizzledBastard
    GrizzledBastard [OP] OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Already have a Power Tray mounted in my engine bay with a Blue Sea 12 circuit box and a breaker. As customary, this is directly connected to the battery.
    I am looking to do something similar, on a slightly smaller scale perhaps, that will allow me to connect accessories that only come on when the ignition is turned on. Can/should this be done similarly with a direct connection to power but activated by a single higher amperage relay that trips when ignition is activated or is there an existing connection somewhere that I might be able to utilize?
    Power taps from a fuse box are of no interest. It's just not clean nor proper for what I'm doing.
    I'd appreciate any input on the matter!
  2. Nov 20, 2021 at 3:59 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    If you want a fuse box like that, You should use power direct from battery through a relay that has its coil connected to an ignition circuit.
    The other option you have is to use power from that unit through a relay to the accessory. You can obviously use one fused circuit for a few accessories as long as you are fused and cabled appropriately.
    You can also take a few of those circuits and make them only power with ignition, but that requires modifying the busbar in that fuse box.
    One last item, I hope the nevative of that fuse box is running to the chassis and NOT the battery. If to battery, you should move it to chassis.
  3. Nov 20, 2021 at 7:24 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    Thanks for the reply.
    Ground on my tray set-up goes to chassis ground so it's proper. Thanks for asking.
    I guess what I was wondering on the accessory set-up was whether there was a regular "go-to" accessory connection that was an easy access or whatever. Just trying to not 'reinvent the wheel' as I get into this.
  4. Nov 20, 2021 at 7:40 PM
    mutely
    I use the cig socket circuit to power the relay coils on mine. But accessory fuse box is under the dash, can’t remember if the OEM main fuse for that is dash fuse box or engine bay fuse box.
  5. Nov 20, 2021 at 7:46 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    That's a good idea! Not a real critical circuit to tie into. I'm not opposed to having that set-up in the cab but I'll consider that as I plan this out.
  6. Nov 20, 2021 at 9:11 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    If you don’t need all 12 fuses to be battery you could switch out the block to this
    https://www.bluesea.com/products/5032/ST_Blade_Split_Bus_Fuse_Block
    Gives you 6 fuses on 2 different circuits, so one will can be battery and one ignition powered.
  7. Nov 20, 2021 at 9:19 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Another option would be to use a RTMR. It will be a bit more $ (and time cutting a hole in the Power Tray). But, it will give you a pretty clean install with constant and relay controlled circuits. Use one add a fuse on an ign circuit to trip the first relay and run the other 4 relays off the first. This will put the smallest load on factory wiring to control 4 relays. You can run the trigger wires into the cab to aux switches to be able to manually control individual circuits when truck is on and have them all shut off when you turn the truck off.
    GrizzledBastard[OP] likes this.
  8. Nov 21, 2021 at 7:35 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    This poses an interesting option. Thanks for bringing this up. I'm going to look deeper into this.
  9. Nov 21, 2021 at 9:09 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    The RTMR is also weather resistant. You won't have to worry as much about getting the fuses/relays wet when cleaning the engine bay.
  10. Nov 21, 2021 at 9:12 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Tap into a non critical ignition switched circuit such as a cigar lighter or the like, use that to positively trigger a relay/solenoid. Wire that solenoid contact to another smaller fuse block.
  11. Nov 21, 2021 at 9:13 PM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    I don't have an aux fuse panel inside, just under the hood. However for the internal stuff I just tapped fuses. I tapped the cig 9v for a USB on the left side of the wheel in the dummy slot and then tapped my tail lights which are the illumination lights for my switches. They come on with the rest of the dash.
    I feel like there's more than two tapped fuses... But my brains been concussed too many times. Just watch the amps. The light bars are directly wired through the fuse panel under the hood but the breaker is nice for people who don't realize my bars and pods will come on without the ignition.
  12. Nov 21, 2021 at 9:24 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    A couple notations for switches and relays.
    Switches: some of the switch blanks have pigtails for OE systems that your truck isn't using. Find your illumination circuit in these pigtails instead of tapping into a circuit that is in use by another switch.
    Relays: the use of non-weatherproof relays can cause issues. Moisture & dust can get into the relays causing corrosion and buildup on the contacts which might eventually cause the circuit to close and activate the accessory without the switch being flipped. For horns, the horn will randomly activate until enough heat builds up to dry out the contact until enough corrosion occurs to permanently bridge the gap. For lights, you will often have the lights glowing at a reduced power which may not be noticable while driving or during the day while parked.
