Help with electrical problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Feb 15, 2010.
  1. Feb 15, 2010 at 7:50 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Maumelle, Arkansas
    2007 V6 Auto
    My son and I went out camping this weekend and a pack rat got in my engine one night and chewed the wiring into that connects my coolent sensor to the engine wiring loom. I called Toyota and they said they only sold the whole engine loom and it was 800 bucks. I rigged the wires together to get home so I can drive my truck. The wire clips into the coolent sensor and then goes about 6 inches and clips into the engine wiring loom. Any idea on how to get this replaced without buying the whole loom. If I go to a wrecking yard will any 2001 Toyota truck part work? Thanks Rick
  2. Feb 15, 2010 at 7:58 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Maybe I'm not understanding the damage from your description ...
    Are you saying there's no way to securely solder a new length of wire into the existing coolant temp sensor line and be done with it?
  3. Feb 15, 2010 at 7:58 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Any one from a 3.4L first gen should work.
  4. Feb 15, 2010 at 8:19 AM
    Ricky B
    Maumelle, Arkansas
    2007 V6 Auto
    EnolaGaia that is what I will probably do. I can't do that personally, so I thought I would just buy the part, now I see I can't buy the part I will look at someone soldering a wire in there.
    98tacoma27 thanks for your reply also.
    Thanks Rick
