Help with fixing Parking Brake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Benmma, Jan 16, 2010.
  1. Jan 16, 2010 at 5:50 PM
    Benmma
    Benmma [OP] Active Member
    Ben
    Athens,GA
    2001 Tacoma 4x4 ext cab
    Hey guys, can someone please help me fix my e-brake. Ive had my truck for 3.5years and I have never had a working e-brake. I have a 01 4cly 5spd.
  2. Jan 16, 2010 at 8:01 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Well, what's wrong with it?
    On a side note, they're pretty unnecessary. I didn't have a working one, then I fixed it, then it broke again after a month and I've given up. The cable is stretched and the back levers are rusted frozen again.
    Instead of a parking brake in a manual, if just leaving it in gear is not enough (it is in most places though obviously), put the truck in Low Range. The lower ratio more than compensates for the lack of a parking brake.
    I would say leave it, more trouble than its worth.
  3. Jan 16, 2010 at 9:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  4. Jan 16, 2010 at 9:16 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    I've had a few replaced through the years.
    Approx. $150.... parts and labor.
    You want an e-brake, get it fixed.
  5. Jan 16, 2010 at 9:25 PM
    STLharry
    Harry
    VT
    Hmmm...I still don't think it's that necessary or worth it.
  6. Jan 16, 2010 at 9:32 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    I use my emergency brake.
    Have to keep in mind if the track "was" to get away while parked, it's a ticket and it won't make your insurance company happy.
    Also nice to let the truck warm up while parked in cold weather.
    Need an emergency brake then.
  7. Jan 16, 2010 at 9:35 PM
    STLharry
    Harry
    VT
    I've gotten real creative with snowbanks. :D
  8. Jan 17, 2010 at 3:25 PM
    Benmma
    Ben
    Athens,GA
    thanks guys, Im going to try and pinpoint the problem tomorrow.
  9. Jan 17, 2010 at 3:38 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    sorry but that's horrible advice.
    you do want a parking brake, what if you go to a buddy's house and he lives on a very steep hill? I wouldn't feel safe leaving my truck without a parking brake, even turned against a curb in low range.
    plus putting it in low range every time you park on a steep hill would be a pain in the ass
  10. Feb 24, 2010 at 12:25 PM
    nofear67
    nofear67 New Member
    Utah
    95.5 Taco
    3 inch add a leaf rear lift and spacers in the front, and complete exhaust system
    I dont know what BENMMA's problem is but my cable broke right at the end of the handle and I just got the new primary cable from the dealer for 40 bucks. It looks like it will be really simple to change out but I can't figure out how to disconnect the cable at the end of the handle where it broke. Everything else for the process looks really easy though, any advice on this would be much appreciated!
  11. Feb 24, 2010 at 4:47 PM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    I'm pretty sure a working parking brake is a DOT requirement in all states. You won't pass an inspection with out one.
