Help with Flowmaster 17432
Discussion in 'Performance and Tuning' started by celec, Feb 12, 2010.
  1. Feb 12, 2010 at 6:50 AM
    celec
    celec [OP] Well-Known Member
    Miami, FL
    2013 TRD Sport MGM
    I just bought a Flowmaster 17432 for my Taco and the idea was to install it myself. I did not read the entire instructions in the page and at the very bottom it says:
    For a cleaner appearance and more secure installation, we highly recommend welding all slip fit connections.
    Anyone has tried to install it without the welding part?!?! I am going to be OK if I don't weld it?
    Any help will be gladly appreciated.
  2. Feb 12, 2010 at 6:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, you will be fine if don't weld it. Just use the appropriate size u-bolts.
  3. Feb 12, 2010 at 7:08 AM
    celec
    Miami, FL
    2013 TRD Sport MGM
    Is it ok if I use the ones that come with the muffler? or should I get something else?
    thanks
  4. Feb 12, 2010 at 8:40 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Use what they give you. Mine is bolted and works just fine.
  5. Feb 12, 2010 at 10:39 AM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    My muffler is welded on, I havent had any problems. But im sure the joint will work just fine too.
  6. Feb 12, 2010 at 10:45 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I have a 2006 Tacoma with the Flowmaster 50 series dual exhaust kit. I didnt weld neither and just used the u-bolts that came with it and it worked out just fine.;)
  7. Feb 12, 2010 at 11:18 AM
    celec
    Miami, FL
    2013 TRD Sport MGM
    Thanks guys, I will post some pictures of the entire thing next week because I will not get it until Wednesday.
    I appreciate all the help!!!!
