Help with Fluid change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ETaco23, Mar 25, 2009.
  1. Mar 25, 2009 at 8:38 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Ganna be changing my rear diff fluid soon, and wanted to know what I should(synthetic ofcourse). And about how much does it take?
    Im thinking the Mobil 1 75w90 synthetic. Is this good stuff?
  2. Mar 25, 2009 at 8:46 PM
    Fly5465
    Fly5465 Well-Known Member
    Gilbert, Arizona
    02 4WD TRD
    36,000 miles
    I recently bought a 2002 Tacoma and I just changed all my fluids. I used Redline 75w-90ns in the diff's. My rear is a locker, . I'm a Redline fan. A little expensive but I think its good stuff.
    Dale
  3. Mar 25, 2009 at 8:53 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    you can't go wrong with redline at all. I use it for my transfer case and tranny. But I use regular 75-90 in the rear with friction additive. Redline in the tranny has helped my shifting though a lot because it CAUSES friction in your shifting linkage. This is good for a manual trans but not good for an auto tranny. hope this helps.
  4. Mar 25, 2009 at 8:54 PM
    ETaco23
    Evan
    PNW
    cool! thanks...
    Anyone else?
  5. Mar 25, 2009 at 8:56 PM
    offroadTRD
    evertaco23, don't make us force you into buying redline for your rear end. It is expensive. my next pick WOULD be mobil 1. I only use mobil 1 10w-30 in my engine for your info, I think mobil 1 will be the only oil I'll ever use in any of my present and future trucks for the engine.
  6. Mar 25, 2009 at 8:59 PM
    ETaco23
    Evan
    PNW
    OK! I think Im ganna go ahead with the M1. Is it ok to use for the trans. case and front diff as well? I thaught I heard some where that it was...
  7. Mar 25, 2009 at 9:00 PM
    offroadTRD
    yah, its fine.
  8. Mar 25, 2009 at 9:01 PM
    ETaco23
    Evan
    PNW
    k. thanks alot!
  9. Mar 25, 2009 at 9:02 PM
    offroadTRD
    no problem man.
  10. Mar 25, 2009 at 9:04 PM
    Fly5465
    Gilbert, Arizona
    02 4WD TRD
    36,000 miles
    I have to agree.... I also use Mobile 1 10w-30 in the engines of all my cars.
    FLY5465
