Help!!!! with Flywheel!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by jesus, Jan 2, 2010.
  1. Jan 2, 2010 at 11:42 AM
    jesus
    jesus [OP] Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    Hey Im not sure what happen but my post is gone I need input on check to see if my flywheel is good I don't want to drop the tran... I have the starter off of it right now any input ia welcome:eek:
  2. Jan 2, 2010 at 11:49 AM
    jesus
    jesus
    bakersfield
    man wheres everyone at???????
  3. Jan 2, 2010 at 11:50 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    what makes you think your flywheel is bad? what are you trying to repair/diagnose?
  4. Jan 2, 2010 at 11:57 AM
    jesus
    jesus
    bakersfield
    Will the start had broken in it and I replaced it but it still sound bad when i go to start it so I though tmaybe the starter I go at autozone was bad just took it bak inand was told it was good they gave me a new one and just wanted to get input didn't know if I should drop trans just to check it out and didn't really want to its alot of work and thought someone on here may know what to do
  5. Jan 2, 2010 at 11:59 AM
    jesus
    jesus
    bakersfield
    I did stick my fingers in it and felt around but couldn't find any really sharp or high/low points in the the space the starter slips in to but someone did say it could of craked
  6. Jan 2, 2010 at 12:01 PM
    cjimenRR
    North Hollywood, Ca
    first off, punctuation marks are your friend :) Second are you hearing like a grinding sound when you first start the car? If so the teeth on the flywheel may be worn out. Turn the crankshaft pulley and check the condition of the teeth, make sure none are broken or worn down
  7. Jan 2, 2010 at 12:05 PM
    jesus
    jesus
    bakersfield
    yup that the sound....... sorry tound dum but remind me again how to turn the pully it's the lower one right???
  8. Jan 2, 2010 at 12:07 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
  9. Jan 2, 2010 at 12:08 PM
    cjimenRR
    North Hollywood, Ca
    sounds like you need a new flywheel. 19mm socket with a breaker bar and turn the pulley, you can maybe try to get lucky and turn the crank via the alternator pulley but that doesnt always work
  10. Jan 2, 2010 at 12:11 PM
    jesus
    jesus
    bakersfield
    thanks I'll go out and do it right now and let you all know what happen once moe thanks
  11. Jan 2, 2010 at 12:29 PM
    jesus
    jesus
    bakersfield
    ok so I found out there's a plat can remove to see half of the flywheel so I took it off and it looks go but I don't know if the where two small bearings came from I sent a pic to twlive I'll see if I can get it here
  12. Jan 2, 2010 at 12:36 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  13. Jan 2, 2010 at 12:39 PM
    jesus
    jesus
    bakersfield
    so I should remove them right ????
  14. Jan 2, 2010 at 12:39 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  15. Jan 2, 2010 at 12:41 PM
    jesus
    jesus
    bakersfield
    cool do you think that could of been why it was still makeing nosie when I went to start it
  16. Jan 2, 2010 at 12:56 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    possibly
