Help with front dif oil change
Discussion in '1st Gen. Tacomas (1995-2004)' started by reg, Aug 19, 2009.
  1. Aug 19, 2009 at 5:25 PM
    reg
    reg [OP] Member
    95 Tacoma
    I've searched and searched, but I can't find an answer on where the filler plug is located for the front differential on a 1995.5 Tacoma. I've seen pictures showing the drain and filler plugs, but it must be for a 2nd generation, since mine doesn't look like that. Also what size are the hex to remove the plugs. I need to buy a set I guess, since mine don't go as big as the one in the drain plug.
    Thanks in advance for any help.
  2. Aug 19, 2009 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Aug 19, 2009 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought it was a little larger?? GAH!
  4. Aug 19, 2009 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No no....I cant remember either.....:eek:
  5. Aug 19, 2009 at 5:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....:notsure:
  6. Aug 19, 2009 at 6:16 PM
    reg
    reg [OP] Member
    95 Tacoma
    Thanks for the diagram.. That's just what I needed. It looks like I need to buy one of those little syringe pump things to get the fluid in that top hole.
    Thanks again.
  7. Aug 19, 2009 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your welcome :)
  8. Aug 19, 2009 at 9:51 PM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    The drain plug is a 12mm allen on early Tacomas. They changed to 10mm later (and in fact, if you buy a replacement plug for any year, it will come with a 10mm). No one has 12mm (I had to buy one special for this, it wasn't in any of my sets), so its a welcome change.
    -Sam
  9. Aug 20, 2009 at 5:57 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    This is just a random questions, but why use an allen head bolt instead of a regular bolt with a normal bolt head?
    Ive always wondered this and never really knew why.
  10. Aug 20, 2009 at 6:19 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I just used some tubing and a funnel. Ran it down through the engine compartment.
  11. Aug 20, 2009 at 6:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know. I thought mine was a 12mmm but couldnt remember...
    Good tip!
  12. Aug 20, 2009 at 6:20 AM
    drew02a
    San Antonio, TX
    So you don't accidentally drain the front diff when trying to change the oil?
