Help with front end noise and vibration.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 5TruckFF, Nov 19, 2015.
  1. Nov 19, 2015 at 7:15 AM
    5TruckFF
    5TruckFF [OP] Member
    San Marcos Tx
    2013 Double Cab TRD OR
    My 2013 TRD DC 4x4 has developed a slight hum and vibration that I believe is coming from the drivers side front end. My truck has 20,000 miles and the noise to me sounds like a bearing as is constant and doesn't change as the speed changes. It is most noticeable at low speeds around the neighborhood. Any thoughts before I take it in to the dealer.
  2. Nov 19, 2015 at 7:17 AM
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Doe sit go away in 4wd? If so it is your driver side needle bearing.
  3. Nov 19, 2015 at 7:17 AM
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
  4. Nov 19, 2015 at 7:23 AM
    5TruckFF
    San Marcos Tx
    Will try that, thanks for the reply.
  5. Nov 23, 2015 at 5:29 AM
    5TruckFF
    San Marcos Tx
    Looks like the noise goes away in 4wd. Tracked it down to the diff bearing on drivers side after more research. Guess I'm going to have to choose between the dealer tsb fix and ecgs bushing. Any thoughts on which direction to go.
  6. Nov 23, 2015 at 4:45 PM
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    I wouldn't bother with the dealer. You'll just waste lots of time and probably end up with just another needle bearing.
    If I were you I would just install the ECGS bushing and be done with it.
    Glad you got it figured out.
    If you need an install tool there are some guys passing them around. If you can't find one I'll be happy to loan mine.
  7. Dec 1, 2015 at 3:02 PM
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    Just lifted my 2014 DCSB and immediately became the newest victim of the needle bearing vibration issue. Just scheduled an appointment at my dealership to get the TSB work done to fix the issue. From what I have read up on the new needle bearing is properly fit and resolves the issue. Obviously too early to know if the fix is permanent however, I figure.....let the dealership do the TSB first and if that doesn't do it, THEN I'll look into the ECGS fix.
  8. Dec 2, 2015 at 10:35 AM
    5TruckFF
    San Marcos Tx
    Did the same today. Going to let the dealer try the tsb fix first while I'm under the warranty. We will see on Monday if it fixes the vibration.
  9. Dec 2, 2015 at 10:56 AM
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Sounds like a few people have had luck with the TSB. Who knows maybe they did fix it? I doubt it though.
    Good luck fellas!
  10. Dec 2, 2015 at 11:24 AM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    I've got the tool available if someone needs it. As long as you'll send it to someone else who needs it after you use it- just pay the postage.
  11. Dec 3, 2015 at 1:03 PM
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    sub'd. wanna see if the dealer TSB fixed the issue.
  12. Dec 7, 2015 at 8:05 AM
    5TruckFF
    San Marcos Tx
    Well the dealer has it now and called to tell me they believe it to be a drive shaft issue. They are replacing it and I'm picking it up tomorrow, so we will see. I'm fairly certain that the driveshaft is not going to fix it. They told me if we still have a vibration that they would do the tsb needle bearing.
  13. Dec 8, 2015 at 5:58 AM
    Boston6154
    Boston6154 Member
    Boston
    07 tacoma dbl cab 4x4
    Hello fellow Tacoma owners ...well I am struggling with the vibration as well a year ago I did wheel bearings it helped but not the cure then the truck went in for the BIG recall FRAME ! so while it was being ripped apart I figured Now was the time to upgrade to Bilstein 5100's but no Lift on the truck also did new shock mount rubber. after 7 Months I got my truck back has a vibration that's getting worse a HUM like a wheel bearing at 30 to 40 But I already did the wheel bearings they have like 7000 miles on them could they have dried up because of sitting for 7 months ??? (anyone know ) so I replaced the enter carrier bearing and u-joints no help I've read about the Needle bearing and I have one from ECGS on the way in the mail does anyone live in the Massachusetts area have the tool I can borrow ? also does anyone know if a Blind Hole bearing puller will work to pull this bearing as I have this puller ? my trucks an 07 dbl cab in near mint con. she's got some age but she runs great and looks great. I am trying to replace all wear and tear Items now that its paid for. its got 127k and I don't have much left to replace. could front axles be causing a vibration (other than the needle bearing problem ) any info is much appreciated ! again anyone have the needle bearing tool I can borrow ?
  14. Dec 8, 2015 at 7:26 AM
    5TruckFF
    San Marcos Tx
    TSB needle bearing will be going in on Thursday now while I'm on shift. The replacement driveshaft didn't fix the noise and vibration. Update to follow.
    Base Camp likes this.
  15. Dec 11, 2015 at 11:41 AM
    5TruckFF
    San Marcos Tx
    Tsb needle bearing is installed and I picked the truck up this morning. So far so good all is quiet in the front end no vibration what so ever. Guess time will tell if Toyota has this problem fixed.
  16. Dec 11, 2015 at 6:20 PM
    sanchez
    sanchez Off Road Member
    Shawn
    Ontario Canada
    sr5 Trd Off Road
    Coverking cr noeprene seat covers, Compustar remote starter, Husky X-act fit floor liners, ARE cap, bed mat, 17"DAI Storm wheels, Goodyear Dura Trac tires, 20%tint
    My vibration is around 90 km which you would think is a balance issue, so I've had the front tires re balanced and helped a bit but is getting worse. I'll have them re do it but I have little faith. It seems a bit too fast but I'm going 4x4'n to see if that works.
  17. Dec 11, 2015 at 6:45 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    The test for the needle bearing is to put it in 4wd. If the noise/vibration goes away, that is likely your issue. One way to test the wheel bearings, is if the noise goes away as you take a corner, it is likely the bearing. Ex: If you turn right, and the sound goes away, it is likely the right wheel bearing that's bad, as the some of the weight is taken off that wheel as you turn right.
    BTW, check your "Conversations". I sent you one. I have a puller I can give you.
  18. Dec 15, 2015 at 4:58 AM
    Boston6154
    Boston6154 Member
    Boston
    Thanks Fitz I replied to you Hope you got it I will definitely take you up on borrowing the puller I will pay for Priority shipping and send it back to you with a check for shipping. can you send it asap ? I'd like to do this job Saturday the 19th Dec.
  19. Dec 15, 2015 at 5:12 AM
    Boston6154
    Boston6154 Member
    Boston
    I did my Front Brakes this last Saturday when I took off the Drivers side rotor to replace I tossed it on the ground without giving it a good look on the back side of the spindle it was COVERED with grease mind you no noise at all and tight ...so I picked up the rotor and the back side it was covered in grease. that NEW bearing has failed! .... maybe the needle bearing is worn causing the early demise of the wheel bearing through vibration ? ... either way I'm not going to play games the needle bearing is going and the ECGS bushing is going in ... I'm also thinking CV axle too along with a new bearing setup ! Big shout out to Fitz for offering his removal tool to me for getting the job done hopefully the job goes smooth and there are no surprise's.
  20. Dec 15, 2015 at 10:54 AM
    TheTacomaGuy
    TheTacomaGuy Member
    2010 White TRD Extended Cab
    Magniflow Exhaust, k&n, 275/65/18 ... And some sidesteps
    might want to check the side input bearings / seals on your front diff also ( the one your CV stabs through going into your diff ) .. i have the same issue, turns out i need a front diff rebuild i will be doing soon.
